01 XJ8 L wheel noise?
Old May 11, 2011 | 10:02 PM
McLovinXJ8L's Avatar
Default 01 XJ8 L wheel noise?
Hello all.
When I start driving between 10-25mph I tend to hear a sound coming from a wheel or wheels. It seems like it happens every 2 seconds, maybe each revolution of the wheels? It's hard to describe, but it does appear to go away/appear very faint at higher speeds. It kinda sounds like a woo....woo...woo....Probably not the best description, but thats all I have.
I'm assuming it may be the wheel bearings?
Any help is greatly appreciated.
Old May 12, 2011 | 06:38 AM
meaculpa's Avatar
Check your tires for any bulges or cuts. Could be a busted radial belt or out of balance tire.
Old May 12, 2011 | 09:05 AM
I thought about that, but just bouht new Michelin Primicy tires all around. balanced, and aligned...I'll still check to make sure.
Thanks.
Old May 12, 2011 | 10:51 AM
JimmyL's Avatar
Actually, I had a wheel bearing sound like that. It sounded like a helicopter was following me around. I'd jack it up and try wobbling the wheel at 9 o'clock and 3 o'clock and 12 o'clock and 6 o'clock and see if you can feel any movement.
Old May 12, 2011 | 11:25 AM
I'm going to assume that I should not be driving this vehicle until I fix this issue. I was planning on going for a day trip, about 120 mile this weekend, but guess not
Old May 13, 2011 | 12:13 PM
rocklandjag's Avatar
I had a similiar noise that turned out to be the drivers front wheel bearing. I did not yet have any place when I wobbled the wheel so it tok time to find the source of the noise. If you move the brakes pads slightly away from the brake rotor and then put the tire back on and spin each front wheel you will feel a grittyness on the side with the bad bearing when you rotate the wheel.
Until I moved the pads away I could not feel or hear the difference. After I did it was obvious right away
Old May 13, 2011 | 02:49 PM
Thanks for the help. Having an oil change Monday and will have the mechanic take a look.
This is the reason why I had a PPI done 1.5 months ago. Hopefully the mechanic will be able to tell me if this is fairly a new problem or old. I do not think the PPI, done at a local Jaguar dealership, should have missed this.
Old May 14, 2011 | 02:38 PM
07XKJaguar's Avatar
I tend to agree on the wheel bearing. I have replaced more left wheel bearings than any other in these cars. My fathers 2 XJ8's and his XK8(with 50k) all needed the left front wheel bearing. I have also installed a left on my friends 99 XJ8 and his needed all rears as well.
Old May 16, 2011 | 11:07 AM
lglitt's Avatar
Default rear wheel bearings
The right rear on my 2002 XJ8 has totally disintegrated. The series of noises it made were very strange insomuch as the first sign sounded like I had run over something on the road - then seconds later - nothing. Car ran great for weeks then the same thing again. Finally, we put it up and sure enough, the wheel has about an inch of vertical play.
Does anyone have a good DIY for making this repair?
I've seen some but the first problem is the reqired tool (at $150). Is this just a 32mm socket?
Larry in Calgary
Old May 17, 2011 | 12:49 PM
Stewarts Automotive gave me a call and advised me the front left bushing is completely thrashed and needs to be replaced. I still think the PPI done by the local dealership should have caught this as it was less than 2 months ago and I have oly put 700 miles on the car.
Amyways, the part will take 2 days to arrive. The repair costs is $316, which seems fair.
Thoughts on the price and the PPI?
Old May 18, 2011 | 07:10 AM
Did they tell you which front left bushing? There are upper and lower shock bushings and 2 upper and 2 lower control arm bushings.
Old Sep 4, 2011 | 09:29 AM
Tanalyst's Avatar
Iglitt,
I had the same issue earlier this year @ 79K miles on my 01 VDP. My mechanic ended up replacing the wheel hub. He was able to get a used hub for $400 and changed it out for $237. I was quite happy he found the used hub, since new ones were in the $2k range.
Tanalyst
dsnyder586
Dec 29, 2024 07:39 PM
Rivguy
Dec 4, 2020 07:55 AM
PMKimpton
Aug 3, 2019 08:22 PM
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
innzane
Sep 2, 2015 10:08 AM
