03 XJR LH Front seat control
Old Apr 13, 2022 | 01:26 PM
dmpsqrd's Avatar
Default 03 XJR LH Front seat control
LH Front seat switches no longer elicit any movement- however the memory switch on the door panel moves the seat to whatever position the memory was programmed to..as always- thanks for any insight!
Old Apr 18, 2022 | 06:49 PM
dmpsqrd's Avatar
This Forum has NEVER let me down...
Old Apr 19, 2022 | 09:07 PM
Gator8's Avatar
Have you checked connections at the switch unit?
Old Apr 20, 2022 | 09:15 AM
dmpsqrd's Avatar
Connections solid and switch(es) have continuity- thanks!
Old Apr 20, 2022 | 03:44 PM
Highhorse's Avatar
I had my switch pack go out about 10 yrs ago, some directions wouldn't work (like yours). I got lucky and found a NOS in my color from a Jag supplier. There are a number on eBay to choose from.
Your only other choice is to pull the switch, if you haven't already to check it...but from how you write, I'd say you've probably done this already.
Old Apr 20, 2022 | 04:00 PM
Highhorse's Avatar
This is all the workshop manual had...
Old Apr 24, 2022 | 06:50 AM
Addicted2boost's Avatar
There’s a high probability that the wires going from the seat switch to the seat ECU have went open circuit. We’ve done several seat wiring harness repairs for that very reason. You must remove the seat and then the seat bottom cushion has to be removed for access to the wiring harness.
Old Apr 25, 2022 | 10:21 AM
dmpsqrd's Avatar
Thanks! The task of removing the seat with it lowered all the way down will be the next task......
Panelhead
Aug 31, 2021 05:54 PM
xjrjag
Jul 2, 2015 04:59 AM
DonsXJ8
Oct 17, 2014 11:43 AM
eurobikefan
Jan 7, 2013 04:59 AM
Donzi
Apr 1, 2011 09:53 AM
