1998 Jaguar XJR Driver Side Door Controls
Old Jun 17, 2024 | 07:20 PM
Ant305's Avatar
Default 1998 Jaguar XJR Driver Side Door Controls
I just replaced the driver door control panel since it wasn’t working and when I had first plugged it in everything was working fine, so I unplugged it to fit it into the door but when I plugged it back in none of the buttons work except the rear passenger window button which got rerouted to the driver window somehow.
File Type: mov
File Type: mov
Old Jun 17, 2024 | 08:54 PM
motorcarman's Avatar
PERFORM A HARD RESET!!!!!!!!!!!!!!!!!!
Disconnect the battery and reconnect. EVERYTHING will be as normal. (I promise)
Old Jun 18, 2024 | 08:29 AM
RandyS's Avatar
It is rather strange how these cars can get confused after what would be a simple
plug and play on other cars.
Old Jun 18, 2024 | 01:25 PM
Faulty messages on the SCP network I would guess.
Old Jun 18, 2024 | 09:25 PM
Ant305's Avatar
thank you I’ll keep you updated on what happens tomorrow currently got sidetracked on a rad leak.
Old Jun 19, 2024 | 07:25 AM
Silverjag0's Avatar
If it's tiny leak use JB weld high heat epoxy leave it for 48h to cure properly
Old Jun 19, 2024 | 03:24 PM
Ant305's Avatar
I made a post about it if you wouldn’t mind looking at it. It seems to be leaking from the mounting point for the fan assembly.
Old Jun 19, 2024 | 05:42 PM
Silverjag0's Avatar
The plastic tank easily crack on these cars and unfortunately there's no plastic tank sold separately you may find the radiator core but not the tank both sides and iirc new radiator will cost 600-800$ not cheap
Good radiator shop can fix it but for now remove the assembly and sand the area let dry then use JB weld high heat let cure for 48h i believe it will stop the leak I had similar leak and jb stopped the leak for 6 months then in a very hot day in summer it leak again I got used radiator in good condition however I had to take it to shop and clean it and replace the transmission fluid cooler because it rust over time and anytime can mix coolant and ATF which is something you don't want . Check the market here you will find used radiator
dwilk
Apr 25, 2022 12:29 AM
Deany Boy
Feb 6, 2018 02:32 PM
Volbrewer
Jun 23, 2015 08:54 PM
jimlombardi
Dec 15, 2012 11:12 AM
Hill2302
Nov 5, 2010 09:22 PM
