1999 XJ8 - slow speed stalling
Old Mar 29, 2007 | 08:58 PM
Envy337's Avatar
Default RE: 1999 XJ8 - slow speed stalling
Check the throttle body for build up around the throttle plate, clean it. Disconnect battery for a few minutes then let it idle till it
warms up.
Could also be a bad MAF sensor.
Old Mar 31, 2018 | 08:25 AM
Takeo's Avatar
I had the same problem until finding out that my gearbox was at fault, just added some oil and problem was gone.
Old Mar 31, 2018 | 11:04 AM
JagV8's Avatar
An air leak is worth checking for. Easy with OBD.
Old Mar 31, 2018 | 03:54 PM
avern1's Avatar
I agree that an air leak is a likely problem. You may also have a stretched throttle cable. Examine the throttle cable and with your finger try to lift it up. If it moves at all then the cable needs to be adjusted, it should be taut. You clip the zip tie that is holding the plastic block in place then remove it and rotate it to remove the slack. Then reinstall with a new zip tie.
You also need to get the fuel trims read at idle and at 2500 rpm while sitting in park and post the results. The fuel trims would identify an air leak.
Old Mar 31, 2018 | 08:25 PM
Don B's Avatar
As Takeo reported, low transmission fluid has been associated with stalling while slowing to stop or to make a turn.
Cheers,
Don
Old Apr 2, 2018 | 07:41 PM
omgimali's Avatar
i think the op has found a solution back in 2007
Old Apr 3, 2018 | 09:03 AM
Don B's Avatar
You're probably right, omgimali, but if the OP did find a solution he or she neglected to report it here.
Cheers,
Don
Old Apr 3, 2018 | 10:46 AM
Jhartz's Avatar
But w/o embarrassing Takeo, we need to read the dates on the posts -- 11 years old!
Old Apr 3, 2018 | 11:48 PM
omgimali's Avatar
Talking
Cheers,
Don
well i hope the op found a solution by now
PlatinumJag
20
Oct 2, 2020 02:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
KingRT
Oct 3, 2015 12:50 PM
mhenz
Sep 14, 2015 07:47 PM
hen555
Sep 7, 2015 11:13 PM
