2001 Jaguar Vander Plas failsafe mode
Old Apr 16, 2011 | 07:36 PM
rickysjag's Avatar
Default 2001 Jaguar Vander Plas failsafe mode
the failsafe mode warning is on. All moniters are complete and no error messages are showing. OBD is clear with P1111 showing. The warning comes on after engine warns up but the cruise control will not work even when light is not on.
Stumped!!!!!!!!!!!!!!!
Old Apr 17, 2011 | 10:55 PM
mzs_biteme's Avatar
Brake switch failed...... Quick swap (~$50) or you can take it out and try to replace the micro-switches...
Old Apr 18, 2011 | 11:17 PM
joolz's Avatar
Brake switch was my problem too. Easy repair..., Whew!
Old Apr 18, 2011 | 11:24 PM
xjrguy's Avatar
+3 Brake switch! Probably has a P1571 Code stored that your scantool can't read.
Cheers,
Old Apr 19, 2011 | 07:42 AM
rickysjag's Avatar
thanks so much. My machanic says its the o2 sensors, but I don't believe it.
Old Apr 19, 2011 | 11:22 AM
mzs_biteme's Avatar
You can test the brake switch... This is my post in the other thread: "When I pulled the old brake switch out, I tested it with multimeter, and found that even in "closed" position, the micro switch had a resistance of about 30ohm, as opposed to ~0... That was enough to trip the computer into thinking that brake is being applied. If I had more time, I could have soldered on a new switch myself for less than $1......."
Old Apr 20, 2011 | 11:44 PM
QuadManiac's Avatar
This (in red above) should read "Open" position... in the closed position the switch should have low resistance, near 0 Ohms, as the contacts are closed - touching. In the open position, the contacts should exhibit near infinite resistance. The 30 Ohms you described (when OPEN), as opposed to the expected very, very high resistance, indeed implies that the switch is bad and can be mis-interpreted by the ECM.
Old Apr 21, 2011 | 07:13 PM
ant17's Avatar
Any details about the replacement process?
It would be good to know.
Where is the switch located?
Old Apr 21, 2011 | 08:02 PM
xjrguy's Avatar
Here is the replacement procedure.
Cheers,
File Type: pdf
Old Mar 25, 2013 | 08:21 AM
rickysjag's Avatar
Default brake switch
Does anyone have the replacement procedure for break switch for 2008 VP?
Old Mar 25, 2013 | 03:41 PM
jimlombardi's Avatar
Hi
Update: TSB is for X308 (1998 thru 2003) - Post# 10 is saying 2008 VDP - X358????
I found this TSB 206-07 on Brake Pedal Switch that motorcarman posted in "Yet Another Failsafe Engine Victim: thread.
Here is the weblink to view this TSB (go down to Page 4 for XJ models - Pages 1 thru 3 are for XK models):
https://www.jaguarforums.com/forum/a...-206-07am3-pdf
Jim Lombardi
Old Mar 25, 2013 | 06:31 PM
rocklandjag's Avatar
I had the same Failsafe mode problem with my '01 VDP. I sprayed the part of the brake switch that connects to the brake pedal with WD-40 and problem solved. Before replacing the switch try the WD-40
Old Mar 25, 2013 | 10:50 PM
PDF file with instructions & illustrations of the Brake Light switch R&R for X350 and X358 XJ:
https://www.dropbox.com/s/gxqn0iqzl0...ch%20R%26R.pdf
If you cannot view the PDF file on the dropbox webpage, then download the file by clicking on the download button, then direct download option (will bring popup - use run option, it open in your default PDF reader).
Jim Lombardi
thedugger1
Sep 24, 2015 05:32 PM
celticpiping
Sep 18, 2015 06:17 PM
Ziggybeben
Aug 30, 2015 02:09 PM
roumor
Aug 28, 2015 01:02 PM
souldoubt
Aug 25, 2015 08:15 PM
