2001 VDP no fuel
Old May 1, 2008 | 05:23 PM
newjagowner98xj8's Avatar
Default RE: 2001 VDP no fuel
Hey,
My 98xj8 did the same thing and I had to replace the fuel pump. In my car it was located in the gas tank. However, I am sure the Jagtechs will chime in. They are truely awesome and will help out. I still need help with mine. Good luck, someone with knowledge will help you out just keep looking back.
Old May 1, 2008 | 06:49 PM
FactoryJaguarTech's Avatar
Fuel pump is in the tank....at the back of the trunk. The pump is on the top of the tank.
I would look at the relay first though. In the trunk fuse box, if you look down the row of relays are like a T on its side. The fuel pump relay is here in red:
Relay
RelayRelayRelayRelay
Relay
Some of the relay slots will be empty, but you get the idea. I would swap relay first. Then let us know what happens.
Old May 1, 2008 | 07:06 PM
jag_genius's Avatar
somebody needs a pump lol
Old May 5, 2008 | 07:12 PM
jag_genius's Avatar
those things holding it back are fuel lines (2).. have to be disconnected from the bottom with quick relesae clips and small hands or be very cleaver with a really long screwdriver.. right on top of the diff.. disconnect parking brake for access
Old May 6, 2008 | 07:18 PM
jag_genius's Avatar
i wud measure the resistance first.. or check power to the pump
Old May 7, 2008 | 08:59 PM
jag_genius's Avatar
right rear marker assembly
toronadomike
Jan 22, 2026 10:13 PM
aholbro1
Dec 29, 2024 06:46 PM
picard
Oct 12, 2015 11:56 AM
Kmw
Sep 8, 2015 04:52 PM
Sprayall
Sep 3, 2015 07:49 PM
