2002 Jaguar XJ8, Gearbox Fault/Failsafe Engine/Check Engine
Old Oct 10, 2025 | 11:22 AM
franky90's Avatar
Exclamation 2002 Jaguar XJ8, Gearbox Fault/Failsafe Engine/Check Engine
Hi Everyone, I have recently been having some issues with my Jaguar, primarily, it turning off randomly. I'm not sure what's causing it, it's almost driving me mad at this point, it'll be fine for a week, and then it'll turn off 5 times in the same day, leaving me stuck in the road until it finally cranks.
Some things I'd like to note:
Alternator is brand new, Battery is brand new, Crank sensor has been replaced recently, I have taken it to the shop a few times, still they do not know what's wrong, everything seems to be good. I can't pull any codes from the car, despite the check engine light being on.
Car will sometimes turn on immediately after turning off, other times it can take a few minutes. Will sometimes jerk a bit and throw up a gearbox fault error without turning off.
If anyone can help me out I'd really really appreciate it, I have no idea what I'm doing here.
Old Oct 10, 2025 | 02:07 PM
xjack's Avatar
By turn off you mean total blackout or just the engine but stuff stays lit, does it crank or not at all?
i would start from checking all grounds and that magic line on the ecu box which is well known offender
Old Oct 10, 2025 | 03:11 PM
franky90's Avatar
It's never a black out, the car has power, it's just shorting somewhere, sometimes it'll crank right back up no problem, other times it will not crank for a few minutes.
What should I be looking for? Pictures if it isn't asking too much! Thank you for the response.
Old Oct 10, 2025 | 03:57 PM
Silverjag0's Avatar
First Get code reader , I suspect the MAF sensor disconnect the MAF and drive the car for while and see if it will turn off as before or not
Old Oct 10, 2025 | 04:31 PM
xjack's Avatar
For starters look here, this nut must have to be clean and tight
check all ground points
and get the scanner, you will need it anyway
File Type: pdf
Old Oct 10, 2025 | 05:29 PM
Jhartz's Avatar
Sounds like oil leakage on one of the cam position sensors or the crankshaft sensor . . . or a loose ground, as noted
Old Oct 10, 2025 | 05:56 PM
Don B's Avatar
Another possible cause of your symptoms is an intermittently failing relay. I'd start by checking all the "Ignition Positive" relays and the fuel pump relay. You can find their locations in the Electrical Guide, which you can download here:
Jaguar X308 Electrical Guide 2002
When you test each relay, test it 10 times in succession. Often, an intermittently-failing relay will glitch one of those ten times and reveal itself.
If you find a bad relay, Bosch makes suitable 4- and 5-pin replacements. I can look up part numbers if you find that you need them.
Cheers,
Don
Old Oct 14, 2025 | 07:01 PM
franky90's Avatar
Hi, okay, I have some updates. I just tested my relays with a multimeter, all of them were fine, however I noticed I was missing a relay in my fuel pump relay 2 slot, so I slotted in the one from the heated backlight relay, Um, I'm not really sure where to go from here, I had cleaned some of the grounds the ones I could reach, like the two in the front. Don't really know where to go from here, I am considering taking it to a jaguar dealer but I don't wanna get charged for shi I don't need, cause there's a lot wrong with the car however none of it is MAJOR. this is the only issue that makes the car absolutely undriveable.
Old Oct 14, 2025 | 07:27 PM
franky90's Avatar
maf sensor possibly? ill try it next
Old Oct 14, 2025 | 07:55 PM
motorcarman's Avatar
An XJ8 (Normally Aspirated does NOT have a secondary fuel pump so NO secondary relay!
Old Oct 14, 2025 | 08:07 PM
franky90's Avatar
Oh, on the PDF it says fuel pump relay 1 and 2, i'm not sure.
Old Oct 14, 2025 | 08:08 PM
franky90's Avatar
ah never mind, I think I know what you mean. It's supposed to be empty!
mdroc1
Aug 8, 2021 08:08 PM
04jag
Mar 9, 2020 07:07 PM
CozDan19
Jul 6, 2015 12:11 PM
yaron369
Jul 19, 2012 04:07 AM
harryc
May 12, 2012 10:24 AM
