2002 XJR with intermittent no crank, no start
Old Nov 16, 2019 | 09:03 PM
brian2891's Avatar
Default 2002 XJR with intermittent no crank, no start
I apologize in advance if this has been covered, but searched and couldn't find anything that applied.
I have a 200 XJR that randomly won't crank and start. When this happens, I put the key in and turn to crank and get a bunch of dash lights. After I do a hard reset by holding the positive and negative terminals together for a few minutes and then reconnecting them to the battery, the car starts and runs with no problem. I initially get a P1797 "CAN TCM/ECM Malfunction" after starting the car the first time, but that fault usually clears itself after about 3 or 4 startups and then the car is CEL free. I'm not sure if this has anything to do with it, but I recently had my throttle body rebuilt/repaired by ASI. I also found new throttle body connectors with pigtails (mine were cracking) to connect to the TPS and PPS from Wiring Specialists and installed them. Everything ran fine for about two weeks and then, I had my first no crank, no start issue. When experiencing the no crank. no start issue, everything (stereo, A/C, lights, etc) would turn on, but when turning the key, there would be a click and then nothing. This has happened to me three times in the past three weeks. Any advice is appreciated.
Old Nov 17, 2019 | 08:01 PM
Highhorse's Avatar
How many keys do you have? If you have 2, then try the other and see what results you get. You may have a key module failing to be recognized by the PATS.
Old Nov 18, 2019 | 02:23 AM
JagV8's Avatar
In case it's that, the PATS light will (after a delay) flash a code - post the pattern if so.
Old Nov 18, 2019 | 08:39 PM
brian2891's Avatar
Thanks for the info. I only have one main key and one valet key. Would the car flash a code if I use the valet key?
Old Nov 19, 2019 | 06:04 PM
Highhorse's Avatar
I cannot answer that since I do not have a valet key.
Old Nov 22, 2019 | 11:16 AM
JagV8's Avatar
I don't know. You'd hope so...
wannoa
Jun 1, 2018 05:30 AM
Rascal
Mar 2, 2018 02:49 AM
geberhardt
Sep 24, 2014 01:10 PM
ONEsicJAG
May 4, 2013 02:47 PM
charlottenian
Mar 30, 2008 12:22 PM
