99xj8 not sure if I have a problem with u joint
Old Feb 19, 2011 | 12:03 PM
jfmelius's Avatar
Default 99xj8 not sure if I have a problem with u joint
For a year now I have had issues and so has my car When I step on the gas at a stop the car will hesitation/jerk forward. If I let off the gas while driving and hit the gas there is a funny feeling in the rear of the car. When driving on the freeway the car seems to have a mind of its own. There rear seems to want to go to the side, I am also correcting. Also, if I turn the ignition quickly several times without starting. I get a stablization and transmission message. Thanks for whatever help you might be able to give.
Old Feb 21, 2011 | 02:12 PM
I really don't know, but from what you describe it most certainly does not sound like a UJ to me.
When they go bad, they tend to clonk as the slack gets taken up, then drive OK until the next time you induce slack.
Or if on a directional drive shaft (not the case on your Jag) they clonk, clonk, clonk when changing direction.
What you are describing sounds more like a suspension issue to me.
Others will chime in.
Old Feb 22, 2011 | 12:23 PM
jfmelius's Avatar
Default Took the car to the dealer
They took it for a test drive and crashed the car. Yes!!!! for real, got the front bumper, left fender and drivers door. No injuries so that is good.
Attached Thumbnails 99xj8 not sure if I have a problem with u joint-img_1354.jpg   99xj8 not sure if I have a problem with u joint-img_1357.jpg   99xj8 not sure if I have a problem with u joint-img_1353.jpg
Old Feb 22, 2011 | 12:48 PM
Holy crap, still, it happens. What was the cause of the crash, car fail or driver fail?
I guess that they will be putting that right together with whatever else was originally wrong, plus any other blemishes as well.
Unless of course they happen to have an XJR they want to swap you.
Like you say no one hurt, that's the main thing.
Best of luck.
Old Mar 1, 2011 | 10:39 PM
Glendoramike's Avatar
Always keep an eye on your tires. I have felt the swaying motion on freeway ramps and when I check the tires, I find that the tread is seperating. I have seen this too often these days. It usually shows up on the inside of the tire first. Use a rag and drag it around the area where the tread meets the sidewall. The steel belt strands sticking out will make you a believer in using a rag.
Old Mar 2, 2011 | 10:44 AM
jfmelius's Avatar
Thanks, I did go to the tire dealer 2X's to have them see if that was the problem. They keep saying the tires are okay. While Jaguar has my car for the damage they did to it. I will have them take a look also. They are keeping my car for 3 weeks to repair all the body damage that was done on the test drive
Old Mar 2, 2011 | 12:43 PM
Cool, it will be like receiving a new car (I hope).
So what did they give you as a loaner 2010 XKR?
Old Mar 29, 2011 | 05:54 PM
jfmelius's Avatar
Default Now I have transmission fault and check engine light
So got the car back from the dealer after they did the bodywork from the crash test they did in it. I got a scanner from local parts store and it is showing P0732 for the code. Anyone able to assist. Thanks
Old Mar 29, 2011 | 05:58 PM
jfmelius's Avatar
Old Mar 29, 2011 | 06:21 PM
plums's Avatar
punch P0732 into the search box and you will get a list of threads on the subject
Old Mar 29, 2011 | 07:07 PM
motorcarman's Avatar
TCM DTC P0732
Possible Causes
Transmission oil level low
Output speed sensor problem
(Refer to P0721 Possible Causes)
Input speed sensor problem
(Refer to P0715 Possible Causes)
Transmission mechanical failure
When fault is detected:
– TCM adopts transmission
electronic limp home mode
(5th gear)
– ECM limits engine power
Old Mar 29, 2011 | 07:13 PM
jfmelius's Avatar
If it is a fliud problem??? Where and how do you check and fill. 99 XJ8
Old Mar 29, 2011 | 08:48 PM
plums's Avatar
As you have just received the car back, it may be smarter to take it back and say "look, this is how you returned the car to me. what's happening?"
Otherwise, if it is related to the "road test", you'll never get it covered after time passes.
Fluid level is checked using a special dipstick tool. The dealer has one, or you can buy it from ebay. They may check your fluid level for you without charge just to be able to say it's not their problem.
Old Mar 29, 2011 | 09:03 PM
jfmelius's Avatar
I was having issues with the car when I took it in. Because there were no error codes they wouldn't do anything. I fact one service tech guessing said it was the throttle body. Though told me to bring it back when it was acting up. So I did. They still couldn't find anyting no codes. i looked on ebay couldn't find what you are talking about.
Old Mar 29, 2011 | 09:55 PM
There is no dipstick.
The fluid level is checked like alot of gearboxes of late manufacture.
Here is a TSB of the procedure.
You can use a non-contact thermometer (the kind you point and shoot) to get a close idea of the trans fluid temp instead of the PDU,WDS,IDS etc.
Could also be a clogged ATF filter or a failed/failing 'A'drum or valve body fault??
Here are some diagnostic TSBs
bob gauff
File Type: pdf
File Type: pdf
File Type: pdf
aholbro1
Dec 29, 2024 06:46 PM
Safari
US Central
Sep 21, 2015 09:34 AM
JimMLiny
Sep 9, 2015 08:13 PM
JagLove86
Sep 6, 2015 10:36 PM
laserguy
Sep 3, 2015 02:02 PM
