AC Compressor Install
Old Sep 30, 2012 | 04:36 AM
Marcus G's Avatar
Default AC Compressor Install
I have a 1998 Jaguar XJ8 and my clutch went bad in my ac compressor, so I disconnected the compressor but I can't get it out of the car how can I get it out so that I can put the new one in please help I have to do this b4 monday
Old Sep 30, 2012 | 05:30 AM
Sean B's Avatar
What's stopping you? have you removed the undertray/fan cowl and tried removing from underneath?
Old Sep 30, 2012 | 08:23 AM
Marcus G's Avatar
Default Removing AC Compressor
ok I have a 1998 Jaguar xj8 and I need to remove the AC Compressor to install the new one I have disconnected the old compressor now I cant get it out the car. I was told to remove the undertray/fan cowl what is that do you have a picture of that
Old Oct 1, 2012 | 06:43 AM
jimlombardi's Avatar
Hi Marcus
I extracted the instructions and illustrations from the JTIS21 Jaguar Shop Manual.
Here is the scrivet (called screw rivet) image) part# KRA106001 Jag dealership retail price is $2 each, discount price is $1.27 each:
Jim Lombardi
Old Oct 1, 2012 | 03:01 PM
Sean B's Avatar
You have to use an 1/8th drill to drill them out.
The screw rivet is a standard motor part, you can buy a bag of 10 for $2, they fit in a standard rivet gun to fit use the largest hole fitting.
The other way of doing it is to replace the scrivet with a push in type fastener, like the inner wing fasteners.
Now the front metal bolts are a different kettle of fish - every XJ I've worked on had then rusted solid (salted roads) replacement is the only option, I replace with high grade stainless nuts bolts and washers, old school.
Old Oct 1, 2012 | 06:19 PM
Marcus
Rockautoparts.com sells a Splash Guard/Skid Plate Pin Kit (ÜRO PARTS Part# BEC19939KIT) has 8 - KRA106001 and 2 KRB100002 in Kit for total of $6.96, but the shipping is $9.46 giving total of $16.42 (they are a California company).
Welsh Enterprises also sells a different kit (8 - KRA106001) for $14.87 plus $9.90 shipping - still not a good deal when compared to Sean B supplier in UK. I have not been able to find the parts shown in Sean B (standard motor parts) on the internet here in the United States.
I would try your local Jaguar dealership parts dept for availability and pricing (maybe your easiest and lowest cost solution).
Jim Lombardi
Old Oct 13, 2013 | 11:01 AM
micalsjag's Avatar
Marcus, how did you get the 2 bolts on the top backside off
Old Oct 13, 2013 | 11:31 AM
sparkenzap's Avatar
This is a mighty old thread to direct a question to a specific poster! Anyway, you just have to use some short 8mm, I believe, conbo wrenches and have patience? I believe I loosened the bolts with the combos, then used a ratcheting comco wrench to remove. Its tricky, but can be done!
silkcat
Jan 18, 2025 04:29 AM
scooternva
19
Oct 27, 2015 02:14 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
tonyforman
Sep 10, 2015 07:23 PM
d a
Sep 3, 2015 02:34 AM
