Another quick question- trick to disconnecting rear fuel line?
Old Oct 20, 2022 | 09:22 AM
Joe Enge's Avatar
Default Another quick question- trick to disconnecting rear fuel line?
It’s the one a bit below and to the left of throttle cable.
im sing a write up that says it’s 1/2”.
the other one just popped right off (3/8”)
I even sprayed it and left it overnight. I still can’t get it separated. I have a bloody knuckle to prove it.
thanks so much!
Old Oct 20, 2022 | 10:02 AM
Addicted2boost's Avatar
Your going to need a skinnier and longer quick release. I use the cheap plastic ones as I got tired of losing the expensive ones.
Old Oct 20, 2022 | 10:29 AM
RandyS's Avatar
Where do you order your "cheap plastic ones" from, Please?
Old Oct 20, 2022 | 10:43 AM
Joe Enge's Avatar
Default I’m stupid
Harbor freight has $5 set, but I couldn’t get them to go over the line
the ones they had are more like a washer looking one.
with 10 minutes or stretching, I finally got it over the line, but it wouldn’t push in. Now it’s stuck lol.
harbor freight also has a $15 set for fords, figured that this cat is a ford, it should work.
like I said, the other popped right off, no trouble at all.
this one, however…
I’ll look at Amazon to see if they have one with a bigger handle?
TB finally off!
what about this gadget?
https://www.autozone.com/test-scan-a...ool/246366_0_0
Old Oct 20, 2022 | 12:55 PM
Quadcammer's Avatar
I used the lisle disconnect tools with just a quick shot of wd40 and they came apart easily.
Old Oct 20, 2022 | 04:47 PM
RandyS's Avatar
Thanks, Quad. I found some pretty neat tools there....and I wasn't
even looking.
Old Oct 20, 2022 | 06:23 PM
Randy, it really depends where I’m at. Sometimes I get them at NorthernTool or at one of the local auto parts stores.
Old Oct 21, 2022 | 09:23 AM
Jtestrake's Avatar
[url
https://www.autozone.com/test-scan-and-specialty-tools/fuel-line-disconnect-tool/p/oemtools-zinc-a-c-and-fuel-line-disconnect-tool/246366_0_0[/url]
That’s the set I use. It’s not the highest quality but it gets the job done.
Old Oct 21, 2022 | 10:37 AM
Joe Enge's Avatar
Well, I tried that auto zone one. It wouldn’t remotely fit. I had to wait for them to open the door.
im almost wondering if these have been replaced.
the previous owner told me all the things he had replaced or upgraded, like the thermostat housing, idling chain etc. the fuel lines do look decent.
my 3/8” ford one finally got it. I took the longer as a handle, so used vise grips.
the bottom clip was stuck on it.
wasted some screwdrivers trying to bend them 75 degrees. They just snapped. Tried some precision ones, but they didn’t have enough oomph. Finally some kind of odd car trim tool was rigid enough yet flexible enough to bend at the weird angle and felt the clip move.
now to figure out where to pry the manifold off. I tried wiggling, but it’s on there.
Old Oct 21, 2022 | 03:50 PM
RJ237's Avatar
Have you removed the screws to the throttle boy elbow?
Old Nov 4, 2022 | 08:44 AM
Joe Enge's Avatar
It was just really really stuck.
I found a couple places to pry cautiously, which was just enough to let me wiggle it a bit more.
then I was able to actually get under it and pried a bit more forceful. It came up finally.
replaced the gaskets, everything seems fine now.
thanks all
XJCCAT
Apr 28, 2022 12:40 PM
V12CAT
Apr 8, 2021 10:24 AM
Jagmike8599
Oct 1, 2018 09:14 PM
ra.stewart
Dec 28, 2011 07:16 PM
