Bluetooth phone and streaming
Old Nov 13, 2018 | 09:44 PM
jonathanelewis's Avatar
Default Bluetooth phone and streaming
Hi all, I have a 2002 XJR 100 incoming and i'm trying to plan my modifications. First thing is first, can someone let me know if it is possible to achieve the following:
I'd like to use the original factory microphone for bluetooth phone calls and i'd like to be able to stream via bluetooth and/or via lightening cable as an Aux. Any help would be greatly appreciated.
Old Nov 14, 2018 | 11:10 AM
Highhorse's Avatar
Welcome Johnathan, please take the time to introduce yourself in the New Member Forum, its a site requirement to review posting protocol and rules, it only takes a minute...https://www.jaguarforums.com/forum/n...-intro-must-5/
Your next action would be to use the Search at the top right, you'll find that by putting X308 at the end of the request, mostly only that model will come up. Other than that, you'll get every model...just an fyi.
So, since your new, here's what member Gopi Hira posted back in '17, ...hope this helps and again...welcome.
https://www.jaguarforums.com/forum/x...ctions-144735/
Old Nov 14, 2018 | 11:24 AM
Thanks so much man!!
Old Nov 15, 2018 | 09:29 PM
nilanium's Avatar
https://www.jaguarforums.com/forum/x...ration-177574/
The CDC bypass gives you audio streaming, the instructions in the link above will explain how to install handsfree calling functionality using a BT receiver and the factory mic.
Old Nov 16, 2018 | 10:18 AM
THANK YOU!
Old Nov 16, 2018 | 06:14 PM
King Charles's Avatar
If your mic is anything like mine they leave a lot to be desired as far as quality & age degradation. I ended up going w/ a whole new set-up, but good luck !
Old Nov 22, 2018 | 04:30 AM
gabrielbecheanu's Avatar
Hi
You can install a Parrot Mki9200. You must change the mic, the factory mic has some electronic pcb you must remove and put the mic that come in the Parrot Kit
I use Parrot CK3000 without streaming.
Good luck
Old Nov 27, 2018 | 04:32 PM
Will any of the previously suggested installs allow for stream through the lightening/aux cable??
Old Nov 28, 2018 | 03:56 AM
With CK
9200 you can stream via bluetooth
you can read the manual from Parrot website
Rocky15
Nov 13, 2015 02:14 AM
bfair
Aug 22, 2013 09:35 PM
dsetter
29
Mar 25, 2013 04:30 PM
ed1655
Mar 15, 2011 11:36 PM
rothe
Audio/Visual Electronics
Dec 5, 2010 03:38 PM
