check coolant temperture
Old Sep 7, 2018 | 01:53 AM
Farid's Avatar
Default check coolant temperture
Hi, I have XJ8 model 2003 , there are many times come out for check coolant temp. I check the coolant but the coolant is about to full !! Any one tell me where is the problem , and how to fix it pls ??
Old Sep 7, 2018 | 06:58 AM
harvest14's Avatar
Do you mean the warning says “coolant level low” or “check coolant level”? Or is it a temperature warning like your post title says?
Old Sep 7, 2018 | 07:32 AM
yeldogt's Avatar
If you are getting a temp alert -- do not drive the car until you find the problem. Is the temp gauge going into the red? The gauge had a dead zone where it sits in the normal range for an extended temp range -- its not linear with actual engine temp. It's overheating if going above -- find the cause before damage is done.
If you are getting a coolant level warning === check coolant. The level needs to be very high in the tank .. if not any sloshing around can set off the warning. The float can also get soggy and sink a bit ... a new one will fix.
Old Sep 7, 2018 | 08:18 PM
Addicted2boost's Avatar
If your NOT having to add any coolant and the low coolant light is on, replace the expansion tank.
Old Sep 8, 2018 | 08:41 AM
yeldogt's Avatar
you can replace the sensor --- only replace the tank if leaking
Old Sep 8, 2018 | 10:41 AM
Jhartz's Avatar
We still need to know what is really going on. Trouble with English language: need to be specific. Is it overheating, or telling you you need to add fluid? If either of these, the advice above will help you solve the problem. But, you might also have a bad temperature sensor (it is located in the crossover pipe in front of the engine). A good OBD II reader can answer some of these questions.
Old Sep 8, 2018 | 10:11 PM
I agree, however more often than not, the float is primarily the culprit even after knocking the tank with the side of a fist a few times to dislodge the float. Expansion tanks aren't too expensive and unless it was replaced within the last two years, it's totally justifiable to replace the whole assembly since its its under a lot of heat, and pressure.
Old Sep 9, 2018 | 01:54 PM
Jhartz's Avatar
I thought I was clear: do nothing until you know what is really wrong!
Harry Peter Rose
Feb 13, 2018 08:14 PM
Colonelxke
E type ( XK-E )
Jun 18, 2016 01:09 AM
Drinkwine47
Feb 8, 2016 06:55 PM
bendougy
Oct 11, 2014 05:23 AM
