check engine light and restricted performance on hwy
Old Aug 12, 2008 | 12:26 PM
red_ghost's Avatar
Default check engine light and restricted performance on hwy
I've had my check engine light on for a couple weeks and just started getting restricted performance when I acheive highway speeds. I checked the ODB2 codes and here's what we get:
P1000
P0171
P0455
Any ideas? I was thinking it sounds like a mass air flow sensor for one, and the vent solenoid for the other. For a couple mins today I thought I smelled gasoline, but there was a city bus in front of me, and it did go away. How would I go about testing both of those things? I'm used to working on Cadillac Fleetwoods where I don't have to worry about that stuff.
Old Aug 12, 2008 | 06:12 PM
red_ghost's Avatar
Default RE: check engine light and restricted performance on hwy
On the way home from work the Restricted Performance light went on again at about 70 mph. It went off after about 2 mins and I went to pass someone. As I was passing and accelerating from about 62 back up to 70 I heard a loud crack and the car decelerated about 10 mph and the light came back on. Scared the hell out of me. When I got home I looked and there was what looked like a small ammount of dried oil in the air intake tubes. throttle plates are kind of dirty too. MAF sensor looks alright. is that dollup of red/brown stuff in the middle of the metal sesor supposed to be there?
It did this also with sports mode on.
Old Aug 13, 2008 | 08:24 AM
red_ghost's Avatar
cleaned the MAF sensor and throttle body assembly with carb and choke cleaner. Did not help at all.
Old Aug 13, 2008 | 02:02 PM
red_ghost's Avatar
no ideas?
where is the evap system located?
Old Aug 14, 2008 | 08:57 PM
oldmots's Avatar
Don't use carb cleaner on the MAF, its okay on the throttle body if there is no coating on yours. Carb and intakecleaners have solvents that can damage plastics and your MAF can be ruined by this. Only use electronics cleaner or CRC MAF cleaner or similar on the MAF. You needto get the obdII system scanned in real time (engine running, on the road) with a laptop systemto see if the MAF, O2 sensors, or something else is out of range. If you guess, you will become a sensor parts warehouse at high cost and frustration. The MAF is a suspect, the scanner will hone in onthe causethough. The evap system is all over the car, in the front and at the tank area and in the tank flange.
Old Aug 15, 2008 | 08:28 AM
red_ghost's Avatar
I'll get someone to look at it on Monday. I don't have that kind of equipment. And, unfortunatly for me; the nearest jag dealer is about 50 miles away. Whats the deal with the oil that was in there?
Old Aug 15, 2008 | 08:53 PM
oldmots's Avatar
The car vents crankcase fumes into the intakes to be burned, the oil condenses out of the fumes. A lousy system but somebody has to do it.
Old Aug 17, 2008 | 11:18 AM
jag_genius's Avatar
right... sounds like you need a mafs and a canister close valve.. .. close valve is behind right rear axle.. but shud be smoked tested to see if that is the problem.. 9/10 it usually is.. but have seen purge valves go as well..
Old Aug 18, 2008 | 08:07 AM
red_ghost's Avatar
2 of the things I figured. Sucks that you really can't test this stuff at home... Thanks for the ideas guys! I have an appointment for it in the next 45 mins.
Old Aug 18, 2008 | 03:17 PM
red_ghost's Avatar
They just called me, 4 hrs later to tell me there was a leak. Well no S**t. They don't know where it is... MAF is bad too. Anyone know where to get one less than $400?
Old Aug 19, 2008 | 01:25 PM
red_ghost's Avatar
They said there is no leak and did not check the canister close valve. They refused to smoke test it becasue they said its not a problem and the code that came up for them was not associated with that, it is associated with a vacuum leak. Sure as heck came up for me though! They are going to replace the MAF with a used one. I'm letting them do it because if that light is still in and I bring in my ODBII scanner and I get the P0455 I'm going to raise all hell.
This is not a jaguar dealership btw, its a European car repair place.
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
tony bosco
Sep 1, 2015 02:06 PM
lee,lee
Aug 31, 2015 04:35 PM
Terrance Williams
Aug 26, 2015 11:50 AM
