"CHECK REAR LIGHTS" everytime I step on the brake
Old Jun 29, 2019 | 09:46 PM
John2002XJ8's Avatar
Question "CHECK REAR LIGHTS" everytime I step on the brake
Anyone have any idea why this would happen? I have changed the brake switch, checked the tail lights (all of them). They are working fine. A friend has a 2000 XJ8 and his lights work just the same but no "CHECK REAR LIGHTS" when he steps on the brake. Any ideas?
Old Jul 6, 2019 | 06:40 PM
This Forum stinks! No one replies to my problem? No one has EVER had this problem?
Old Jul 6, 2019 | 08:09 PM
Coventry Foundation's Avatar
John check your bulbs. If someone has replaced an OEM one with a cheap one the car will read it as a failure even though it works!
Old Jul 6, 2019 | 08:18 PM
Cambo's Avatar
Your car is an X308. You posted in the X350 forum, I've now moved this thread to the X308 forum.
X350's have LED rear lights, so yes quite likely nobody reading the X350 forum had that problem...
As our friends at Coventry Foundation suggest, you should exchange your brake light bulbs for some quality brand-name ones, or maybe even genuine Jaguar ones.
Good luck.
Old Jul 6, 2019 | 08:46 PM
motorcarman's Avatar
I've had this problem but I don't know what car you have!
(I hate mystery cars)
Before you whine about how nobody will give info about your car........... How about telling us what car you have????
I'm out!!
bob
Old Jul 6, 2019 | 09:25 PM
electrovolt's Avatar
if all the lights are good,,, check battery voltage if too low... get a full charge and warning will go...
Old Jul 6, 2019 | 11:29 PM
grantorino62's Avatar
Bulbs of different brands will do this OR brass bulb bases vs/ silver ones will trip this message as well and illuminate just fine. I presume the center brake light works? And using your user name to identify your car is not a good idea. I use GranTorino, never owned one !
Old Jul 7, 2019 | 11:36 AM
Jhartz's Avatar
On this forum, there are many threads on what your problem could be. Please review them. With the information you have provided, it sounds like you have a bad SLCM. Need to go under your boot carpet, on the left side, and you will see a listing of key modules. You need to buy one that matches: the frequency is important.
Old Jul 11, 2019 | 05:38 AM
ca3145's Avatar
Default check your grounds
John: I had a similar problem when I stepped on the brakes i'd get check rear lights flash on the dash.I cleared it by removing ,cleaning and tightening ground nuts in the spare tire compartment.Remove battery posts before Doing the work. Laters Carlos
Old Jul 11, 2019 | 06:34 AM
yeldogt's Avatar
Also -- my memory is the center set is not tied into the module.
Old Jul 11, 2019 | 06:46 AM
Lady Penelope's Avatar
Old Jul 12, 2019 | 11:23 AM
JaguarRookie's Avatar
Default 1999 XJR bulb failure warning.
I had the same problem (intermittently) on my 99 XJR. New bulbs didn't fix it, but another stab at it using dielectric grease worked. I suspect a bit of corrosion that is invisible.
Old Jul 12, 2019 | 07:14 PM
user 652867429824's Avatar
I had the same problem, only not every time I put the brakes on, but often. I took out each bulb and cleaned them and the socket, whether it looked like it needed or not. that seemed to cure the problem for me. Oh, and when I put the bulbs back in the socket, I put a bit of bulb grease on to help deter further corrosion
Old Jul 12, 2019 | 08:24 PM
There are current sensors in the 2 light modules in the X308 which give you the warning light
It has a history of the rear lamp assembly ground going bad not allowing current but the lamps will light
sub par bulbs will also limit current
Battery fuse link nuts tight ?
Old Jul 12, 2019 | 09:33 PM
I am not using my user name to identify any car. You make assumptions. That's a bad idea.
Old Jul 12, 2019 | 11:39 PM
"You talking to me? "
Both you and he don't identify your year/model of car in your signature? Why?
Old Jul 13, 2019 | 09:03 AM
This is a civil forum for people to help each other
princemarko
Jun 7, 2022 11:23 AM
Reid William Kaufman Worthen
Jan 1, 2019 08:49 AM
IronCobra
Dec 31, 2018 07:49 PM
Julian Cedrone
Mar 10, 2011 12:52 PM
Azurc
May 12, 2009 07:00 PM
