climate control only hot air
Old Jan 18, 2018 | 03:06 PM
justas696661's Avatar
Default climate control only hot air
so another problem appeared with my x308 jaguar, climate control blowing only cold or max hot air, if i set to low it blows cold air, then if i set to 17C it blowing very hot air, same as max.
where to look? maybe interior temperature sensor? maybe need to replace all climate control module??
sorry for my bad English
Old Jan 18, 2018 | 03:48 PM
avern1's Avatar
First there should be a button on the climate control for outside temperature. Press it and see if the outside temp is fairly close to the actual temperature. The ambient air temp sensor can play havoc with the controls if it has gone bad. Mine would give heat except on HIGH. The ambient was reading 137 degrees F when it was 32 degrees outside.
There is also a sensor that can get plugged up it is the cabin temp sensor. To the left side of the steering wheel you will see on the dash a perforated area. That is the cabin sensor and aspirator fan inlet. Try a vacuum cleaner hose over it to remove dust and lint.
Old Jan 18, 2018 | 04:05 PM
Lady Penelope's Avatar
There is a self test that will give you a code if it is electrical and not if it's dirty .
http://www.jagrepair.com/images/Trai...des/703_SG.pdf
Page 45 for X308 and page 110 for self test , codes somewhere else
Codes pdf in post # 8
https://www.jaguarforums.com/forum/x...nfo-faq-66454/
Old Jan 19, 2018 | 03:07 AM
Stu 1986's Avatar
Check none of the pipes are trapped or blocked in the engine bay around the control valve, I had a similar issue pop up a few weeks ago. When I checked the area, I discovered I’d trapped one of the hoses between the top of the control valve and the expansion tank. No problems since.
Old Jan 19, 2018 | 11:18 AM
where control valve is located?
Old Jan 19, 2018 | 08:00 PM
The control valve is buried but you can run it back and forth with a 9 volt battery at the Climate Control ECU connector at pins x and y to see if it drives . you can see the position sensor change at pins a and b .
Old Jan 20, 2018 | 01:38 AM
it drives, all okay, also i have cleaned cabin temp sensor, and tested outside temp sensor, is very accurate. i do not see any trapped hoses, ..
problem still not solved, climate control blows maximum hot air, or cold, if set on low.
Old Jan 20, 2018 | 03:33 AM
ericjansen's Avatar
Did you get any codes running the self diagnostics on the climat control?
Old Jan 21, 2018 | 03:11 AM
Stu 1986's Avatar
The control valve is located directly underneath the expansion tank, you should be able to see the top of it and it's wiring plug by removing the centre section of the scuttle cover and looking in that area.
Old Jan 21, 2018 | 10:08 AM
i have error code 14, well and i have checked control valve, it looks like new from the inside.
also my jaguar have LPG system installed, maybe hoses that goes to LPG reductor is connected wrongly
Old Jun 10, 2020 | 04:29 PM
stuart derry's Avatar
Hello justas696661, I know this is an old thread but how did you solve this in the end? I'm having the exact problem right now
keithbush
Nov 13, 2014 02:32 AM
jag_guy_2020
Aug 16, 2014 06:17 AM
richard300
Apr 12, 2014 01:09 AM
PEM24
Jul 31, 2013 07:56 AM
sandrewfla
42
Jun 23, 2010 04:10 PM
