Coolant Temperature Alarm
Old Apr 27, 2018 | 12:35 AM
Platinum XJR's Avatar
Default Coolant Temperature Alarm
Hello.
I am looking for a way to monitor my coolant temperature and have an audible alarm if the engine was to overheat.
I've looked at:
Engine Guard
Engine Watchdog
ScanGuage
Have any of you used one of these?
Thoughts?
Suggestions?
If I could find a place to mount standard gauges, I'd run a water temp, oil pressure, and fuel pressure gauge.
I cannot think of a location to place traditional gauges other than the A-Pillar, and I don't want to do that.
I could mount any of those three systems on my Kuda console mount.
Thank you for your help.
Stewart
Old Apr 27, 2018 | 12:58 AM
King Charles's Avatar
By our very own forum member & uses the existing gauge.
XK8 / XKR / XJ RealGauge - TheJagWrangler
I run the Torque Pro app w/ a bluetooth OBD dongle & you can set an audible alarm as it real time monitors as well.
Torque Pro
https://play.google.com/store/apps/d...orque&hl=en_US
Old Apr 27, 2018 | 01:07 AM
Thanks for your help!
Old Apr 27, 2018 | 07:15 AM
harvest14's Avatar
I have the Ultra-Guage blue. It monitors a couple dozen parameters and I can use my phone as the display. I have an alarm set for coolant temperature. I could set an alarm for any parameter but coolant temperature is the only one I feel is necessary.
Looks like they are having a little sale, too.
http://ultra-gauge.com/ultragauge-blue.htm
Old Apr 27, 2018 | 07:57 AM
yeldogt's Avatar
UltraGauge Blue OBDII Scan tool & Information Center
That looks like a cool little device!
Old Apr 27, 2018 | 08:05 AM
WhiteXKR's Avatar
Torque Pro
Also, my RealGauge includes an audible alarm for oil pressure as well as coolant. None of the OBDII devices can offer an oil pressure alarm because they do not monitor the low oil pressure switch.
Old Apr 27, 2018 | 08:57 AM
yeldogt's Avatar
There is less of a need -- one had to monitor the oil in some vehicles 50 years ago ... sort of.
The overheat problems with the X308 have to do with maintenance -- the early cars need the water pumps and thermostats replaced -- with a proper flush and proper coolant added. The non-SC cars need the Thermostat tower switched out .. after that it's maintenance.
Old Apr 27, 2018 | 02:14 PM
WhiteXKR's Avatar
The oil cooler hoses on the supercharged vehicles can and do fail, particularly near the crimp. I have been informed of some saves from the RealGauge alarm.
Old Apr 27, 2018 | 02:44 PM
Sean B's Avatar
just plug one of ^^ this guy's kit's in, it re-calibrates your existing gauge, the simple install makes it a no brainer. And it works beautifully
Old Apr 27, 2018 | 10:57 PM
That sounds great.
Thanks for your input everybody!
Stewart
Old Apr 28, 2018 | 10:59 PM
I just checked this out. I have to say that I am impressed. Thanks for posting this.
user 652867429824
May 4, 2018 07:40 AM
