Cruise Control
Old Dec 23, 2013 | 09:55 AM
cyberstitch's Avatar
Default Cruise Control
Hi folks,
This has probably already been answered somewhere so feel free to show me the url -
My XJ8 does not have cruise control. Is it possible to retro fit and if so whats the best way to do it?
TIA
John
Old Dec 23, 2013 | 10:14 AM
test point's Avatar
Welcome to the forum Cyber!
The early cars handled cruise with both hardware and software and then in the '99-'00 MY time frame changed to software only so it would help to know what is your model year.
The mods would also appreciate it if you would go to the new member forum to introduce yourself.
Old Dec 24, 2013 | 03:56 AM
Model year hmmm...
Would the vin number help?
SAJJJALG3CH877397
Its on a V plate
TIA
Old Dec 24, 2013 | 08:31 AM
jimlombardi's Avatar
Your forum member page - about me section, says you have a 2000 XJ8.
The Vin code SAJJJALG3CH877397 in the previous post seems to be for a 1987 XJ40 -
code breakdown:
SAJ (mfg code - Jaguar)
J (marque code - Jaguar)
J (code for model type -XJ40)
A (code for trim class - baseline)
L (code for body - 4 door saloon)
G (code for engine - 2.9 L B)
3 (code for transmission - Auto RHD)
C (code for model- AJ6 coupe and convertible / XJ Series III
H (code for plant - Actually, > 1987, this is supposed to be emissions equipment)
Last 6 digits (code for serial - 877397)
source is:
Jaguar VIN decode results
Jim Lombardi
Old Dec 24, 2013 | 01:49 PM
Thats strange - i took that vin number from the last MOT certificate. I will look under the bonnet on Boxing Day.. but its defo an XJ3.4 on V plate. Just got it last week see here.. Yes I know I paid over the odds but its a cracker...
2000 (V) JAGUAR XJ8 3.2 V8 AUTO RED CLASSIC LOW MILES STUNNING NO RESERVE | eBay
Old Oct 24, 2014 | 11:53 AM
lukie's Avatar
I have an 1998 xj8 but cannot find cruise control on the gear console, could it have been moved or just not fitted?
thanks for any input from this golden website as usual.
Old Oct 24, 2014 | 12:01 PM
jimbov8's Avatar
If you don't have the resume/cancel/set switches on the right side of the steering wheel and the cruise button at the bottom of the J gate, then it isn't fitted.
Hope this helps,
Jim.
Old Oct 24, 2014 | 05:50 PM
Here is a JPEG file of the 1998-1999 Jaguar XJ Drivers Handbook page on Cruise Control:
Note the "(where fitted)" phrase.
Jim Lombardi
Attached Thumbnails Cruise Control-1998-jaguar-xj8-cruise-control-page-drivers-handbook.jpg
Old Oct 25, 2014 | 10:42 AM
lukie's Avatar
Default cruise control
just as I thought! so I will just have to swap it over from my xj8 sport, as in the reading it should not be to complicated.
A big thanks to all that responded.
Old Oct 25, 2014 | 03:37 PM
RJ237's Avatar
But it will be complicated. Your ECM has to control it, but you don't have that function programmed, and you don't have the vacuum reservoirs behind the fender liners, or the vacuum switch on the throttle body
Old Oct 26, 2014 | 05:28 AM
lukie's Avatar
Thumbs up
Hi RJ237, if you read my comment I have all this on my XJ8 Sport transfer from one car to the other, all the bits that are needed for such a transplant are ont the sport.
but as I always do.
Tank you For Your Comment.
All comments are a jewel in the crown on this site.
Old Oct 26, 2014 | 05:38 AM
RJ237's Avatar
Did you also transfer the clockspring, or did the cc wires to the ECM already exist from the original clockspring? I know the cars were often wired for options that were not installed.
Old Oct 28, 2014 | 10:56 AM
lukie's Avatar
Talking cruise control
This is to RJ237, Hi mate, I haven't a clue yet as I am about to start the engine transplant next week and the car is not at my home address but I will post my findings when I come to refit/ try to refit the cruise into the basic xj8 from the sport.
lukie
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
leep123
Sep 30, 2015 03:41 PM
Camnelson324
Sep 27, 2015 08:48 AM
zdrapec
Sep 25, 2015 05:49 AM
