Diff Fluid change
Old Nov 3, 2012 | 02:19 PM
MikeLss1's Avatar
Default Diff Fluid change
So I'm going to change the diff fluid for my 2003 xj sport, the fluid i'm using is:
Castrol Syntrax Limited Slip 75W-90 Synthetic Gear Oil
I'm pretty sure my car isn't an LSD car, but I did the research and I couldn't find a really definitive answer nor could any of my friends.
Does anyone have an objection to that?
Old Nov 3, 2012 | 07:38 PM
RJ237's Avatar
This topic has been addressed on the XJ6 forum and the consensus is that you have nothing to worry about. While I don't recall if the Castrol Syntax was specifically mentioned, the use of synthetic and limited slip were considered. The use of ordinary lube in a limited slip diff. is definitely a bad idea.
Old Nov 3, 2012 | 08:15 PM
MikeLss1's Avatar
Okay cool thanks - I got the castrol cause I read that forum - I should have been more specific:
In my non-jag experience - you can use limited slip diff oil in a non lsd car, but not the other way around. Since I'm not sure if mines an LSD, and I can't figure it out (though i know the majority aren't) I got the LSD fluid... is the "limited slip fluid" thing a problem if it isn't LSD?
Old Nov 3, 2012 | 09:19 PM
motorcarman's Avatar
There is no OEM limited slip in the X100/X308 cars. Synthetic 75W90 is fine for a diff oil change.
bob gauff
Old Nov 4, 2012 | 11:28 AM
MikeLss1's Avatar
Cool thanks
Old Nov 4, 2012 | 07:30 PM
MikeLss1's Avatar
Just finished changing the diff fluid, here's a picture of the fluid I pulled out of it with 68k miles:
It's not the worst I've ever seen but I'm glad I changed it.
I'll let ya'll know if I have any problems running the castrol... which i really hope i won't have to do!
Thanks for the help!
here's the link if the pic didn't post, it didn't show up in my box:
http://i287.photobucket.com/albums/l...1-04171342.jpg
Old Aug 22, 2015 | 06:58 PM
trottier.ed's Avatar
Red Line has stopped labeling their Diff. Gear Oil (LS) Limited slip, and (NS) Non-lilmited slip. Reading their website, virtually identical descriptions are found for 75W-90 (Jag '97-2003 Spec), NEW 75W-110 and 75W-140 products. What they present is "no additional additive required" for limited slip diff. SO, the questions are: Is current Red Line product line suitable for BOTH, NS and LS diffs? And some additive is needed for "some" LSD applications? '97 to '03 is NON-limited slip, so the question is far from academic. In Southern climes (I live in Aiken, SC), where ambient temps are 90 to 100 deg. F. for maybe 2 or 3 months, we read about many XJR owners going to 75W-140 diff. lube. Again, without any apparent "cautions." I have chosen a "mid-point" NEW Red Line product, 75W-110, of which 2 qts rest in their delivery box on the floor next to me. Label reads, in part, "GL-5 High-Performance Lubricant for LIMITED-SLIP DIFFERENTIALS" In absence of a conversation with Red Line, anyone have DEFINITIVE info on application/use for NON-LSD XJR (308)???
Old Aug 22, 2015 | 09:14 PM
TreVoRTasmin's Avatar
I have valvoline syth. 75w-140 in mine and the sky hasn't fallen yet. Have been running non spec fluid in my 85 TVR with a jag rear for years as the fluid for that isn't available. If you're concerned why not just order the jag stuff. You can get it for $80 for 2 liters which isn't a ton more than redline is if you think about it. It isn't like you need to do it every year.
Old Aug 23, 2015 | 07:30 AM
80sRule's Avatar
I'm looking at that exact Valvoline gear oil for my XJR and XKR; the VV982 Valvoline Full Synthetic 75W140 gear oil. How long since your change?
In my XKR and XJR I'm running the following fluids:
-Mobil 1 5W40 High Mileage Synthetic ($40-50 per change assuming retail)
-Valvoline Synthetic ATF VV322 ($50 per change assuming retail)
-Valvoline Synpower Brake Fluid ($20 per change)
-GM Supercharger Oil ($16 per change)
-Castrol Syntec Dexron III ATF for PS (new bottles from Corvette I had left over) [$10ish?]
-Pentosin CHF11S for top (idk $60? for the change I did replacing a ram)
I'm not paying $80 for two quarts of gear oil. I can get 2 quarts of the Valvoline for $26 OTD and it's an excellent product.
Old Aug 23, 2015 | 02:03 PM
A month or so in the XJR, about to do the Xk8, can't say I'd recommend it to anyone but I am not one to believe that there is anything special in these difs that a good quality gear oil can't handle. For anyone else I still recommend sticking with the stock stuff.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
kstevusa
Sep 7, 2015 01:12 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
pnwrs2000
Sep 3, 2015 11:55 AM
