Disconnect battery for short term storage?
Old May 30, 2011 | 06:14 PM
Boomer from Boston's Avatar
Default Disconnect battery for short term storage?
My XJ8 needs to sit idle for 2 - 3 weeks. Is it a good idea (or does it hurt anything) to disconnect the battery for the duration?
Old May 30, 2011 | 08:23 PM
sparkenzap's Avatar
I have never had a problem with 2 to 3 months between starts. If you pull the plug, I THINK you will reset thge adaprions and will require an OBD drive cycle before you can pass emissions, if you have such a test where you live.
Old May 30, 2011 | 08:49 PM
Emissions test is once a year, in my case in the fall for this car. I have had ongoing issues with the battery getting low after awhile, so I don't want to have to mess with that until then.
I didn't think there should be any issues, but wanted to be sure.
Old May 31, 2011 | 10:00 AM
Brutal's Avatar
You can issues with most notably window and lock operation. I see this when cars are left without battery power at body shops and other disconnected reasons. I would recommend a battery tender. Theyre only $30-35 at batteries plus and other outlets
Old May 31, 2011 | 10:09 AM
Would remotes have to get reprogrammed?
Old May 31, 2011 | 04:44 PM
budinsc's Avatar
boomer, when we travel for extended periods, we simply put trickle chargers on our cars. they are inexpensive and can be bought in most auto supply dealers like zone, advance etc.
rock on, bud
Old May 31, 2011 | 05:36 PM
Brutal's Avatar
NO
Old May 31, 2011 | 06:00 PM
pezzonovante88's Avatar
I certainly wouldn't. Mine has sat for several months and has started up just fine afterwards.
Old May 31, 2011 | 09:50 PM
yeldogt's Avatar
My cars sit for 3 - 4 weeks all the time --- I never do anything with them. The ones used only in the summer get put on a tenter.
aholbro1
Dec 29, 2024 06:46 PM
philwarner
Oct 4, 2024 01:37 PM
Wolfy
May 28, 2024 08:06 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
DuhCar
Sep 11, 2015 10:58 AM
