Door Lock Actuators
Old Jul 26, 2010 | 03:23 AM
Cadillac's Avatar
Nalley Jaguar , JPAM (our vendors )
If those are not available you can try these
www.motorcarsltd.com
www.jagbits.com
Old Jul 26, 2010 | 05:07 AM
theusualsuspect's Avatar
got mine on ebay for 60 bucks..labor to install it...230! ouch
Old Jul 26, 2010 | 08:10 AM
benebob's Avatar
ud
You can buy one for $3 off ebay. The actuator itself is just a ford part # unit. I just replaced mine not knowing what was wrong so I bought the whole assembly off ebay used for $35 (shipped from England).
Old Sep 7, 2010 | 12:35 PM
trevoroq1's Avatar
Default Door lock actuators
I have my drivers door not locking , I can only buy the whole lock unit in the UK but have seen just the actuator for sale in US for 7.95 do you know anyone that ships to the UK they all seem to only ship to US or Canada
Old Sep 7, 2010 | 12:56 PM
In the UK, have you tried David Manners or British Parts UK.
Or a quick UK Google for Jaguar spares will give you a decent list of breakers.
Old Sep 9, 2010 | 11:08 AM
trevoroq1's Avatar
Has anyone used one of these $5 actuators ?
Old Sep 9, 2010 | 12:32 PM
H20boy's Avatar
which $5 actuator?
Old Sep 9, 2010 | 02:48 PM
benebob's Avatar
ud
I bought one when I did mine but had a used set up as well. Went with the used set up. It does look identical though.
Old Sep 10, 2010 | 08:09 AM
trevoroq1's Avatar
Did you take everything out or can you just take out the lock fitting ? Sorry just realised im in the XJ forum I have an S type
Old Sep 10, 2010 | 08:29 AM
trevoroq1's Avatar
Default Found one
Just found one in UK will try it , only 4.99 stirling
Old Sep 10, 2010 | 02:59 PM
benebob's Avatar
ud
I had to loosen everything in the xj rear to get the actuator to a spot where I could remove it. Going with a aftermarket likely means you'll need to solder it in so you should just be able to remove the actuator and the harness, solder then put back in. It isn't the easiest job to do as access in any door pretty much blows.
Old Sep 11, 2010 | 05:11 PM
Rae's Avatar
Rae
Default Actuator going down then immediately up
OK Guys, I guess this is my weekend for somewhat stupid questions....My front passenger door actuator goes down when locked, but then immediately raises up while the other doors remain locked. Is this going to be an actuator problem, or an electrical signal from somewhere else raising this one actuator back up. Also, upon looking at a spare left handed door I have, it would appear that if I replace just the actuator, that I will need to splice into existing harness as it has two leads on it from one plug. Is this so, or am I confused? Thanks in advance for your patience.
Duh...just re-read benebob's response which answers the splicing question.
Ralph
Old Mar 27, 2011 | 08:02 AM
yardpro's Avatar
does anyone know what year/model ford solenoid will work on my 03 xj8?
My solenoid has failed.
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
mrsimpson
Sep 15, 2015 01:10 PM
Ipc838
Sep 13, 2015 03:27 PM
findre
Sep 10, 2015 05:46 PM
