Engine Assembly information
Old Jul 31, 2013 | 02:46 PM
BW_Hunter's Avatar
Default Engine Assembly information
Hi All,
I looking for a engine assembly information for my '99. I downloaded the latest JTIS and while that has a lot of information, it is lacking meat on the engine itself. Are my search skills letting me down and this information is right in front of me? Anyway, if someone could direct me to an online engine resource I'd very much appreciate it.
Thanks in advance,
Old Jul 31, 2013 | 03:05 PM
RJ237's Avatar
Post your question on the XJ (X308) forum and you will get help. This is the XJ6 forum.
Old Jul 31, 2013 | 05:22 PM
Originally Posted by BW_Hunter
......... looking for a engine assembly information for my '99.............,
Bruce,
I've moved your question from X300 section to X308 section. members here with the same model as you have will be able to advise.
Old Jul 31, 2013 | 05:59 PM
dsnyder586's Avatar
I would advise you to consider a used replacement engine instead of a full rebuild- much, much cheaper.
Old Jul 31, 2013 | 06:24 PM
BW_Hunter's Avatar
Originally Posted by GGG
Bruce,
Thanks, Graham, the iPhone print was just too little for my old eyes...take care.
Old Jul 31, 2013 | 06:25 PM
BW_Hunter's Avatar
I'm sure you're right, I was just looking for head removal/replacement...torque settings, specs, rtc.
Thanks, much!
Old Jul 31, 2013 | 08:06 PM
dsnyder586's Avatar
AH- just the heads? That's definitely doable- Engine course
That should give you all the info you need.
Old Jul 31, 2013 | 09:13 PM
motorcarman's Avatar
I uploaded my student guide 168 that I had made into a .pdf at a copy store.
It is in the large file section.
I also have the Engine Course 180 but it is ONLY the V8.
You're welcome.
bob gauff
Old Aug 1, 2013 | 12:23 AM
MoscowLeaper's Avatar
The information about an engine can be found in XK8 section of JTIS It's a well-known bug
Old Aug 1, 2013 | 06:38 PM
BW_Hunter's Avatar
Perfect!
Thanks very much.
Old Aug 1, 2013 | 06:46 PM
plums's Avatar
The "thanks" button is at the bottom of the posts which you find useful.
Old Aug 1, 2013 | 07:10 PM
dsnyder586's Avatar
Hey Bruce,
Keep us posted on the progress- pics or it never happened.
Old Aug 1, 2013 | 08:08 PM
avt007's Avatar
Do a search for "extract" on this forum, and you find pdf extracts of many engine jobs. I am doing head gaskets right now and all the info is in the JTIS extracts. Many thanks to Jim Lombardi.
Forcedair1
Sep 8, 2025 01:57 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
KarimPA
Sep 3, 2015 07:32 PM
innzane
Sep 2, 2015 10:08 AM
TC Johnson
Sep 2, 2015 09:30 AM
