Engine Compatibility
Old Mar 22, 2011 | 08:04 PM
h_mihm's Avatar
Default Engine Compatibility
Hi there,
I have a 99 XJ8, and I want to replace the engine. The closest in my area I have found is a 2000 XK8 with 65k. My first question would be.....Is this engine compatible ith my car? Second question is.....Do the 2000 models have problems with timing tensioners around 70k as well? The fella who wants to sell me the engine says it is compatible, but I am still leary. I have had problems with the crank shaft and had the block replaced, with no sucess from a crappy mechanic....now I just want to replace the engine and be done with it. Does anyone have any ideas or comments?
Thanks in advance for any constructive input!
Holly
Old Mar 22, 2011 | 08:35 PM
Disco stu55's Avatar
theres a ls1 swap on here...might be more reliable and give you more power options
Old Mar 22, 2011 | 08:45 PM
j_bond's Avatar
I would say......... Post this in the XK8 area.....
Old Mar 23, 2011 | 04:25 AM
Cadillac's Avatar
Moved off to the General Tech Help , you should be getting more answers from tech guys
Old Mar 23, 2011 | 08:18 AM
motorcarman's Avatar
Any AJ27 engine from XK/XJ will work for you.
You can use 1999 to 2003 XJ8 or 1999 to 2002 XK8.
Forget about Supercharged engines as they are too different for a direct fit.
I would still pull the cam covers to check for updated tensioners on any engine I bought and it is easier with the engine out.
bob gauff
Old Mar 24, 2011 | 10:26 AM
h_mihm's Avatar
Thanks for the advice Bob, I really do appreciate it! I will have them check for the updated tensioners. If they are not updated, is it a complicated job to update them?
Old Mar 26, 2011 | 04:22 PM
test point's Avatar
D.K
Dec 10, 2023 02:05 AM
Bcrary3
Sep 12, 2021 05:41 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
