engine coolant light
Old May 27, 2015 | 03:40 PM
holiday's Avatar
Default engine coolant light
Does anyone know what would cause the engine coolant light to stay on. 2003 xj8 hard body. Car does not run hot and the fluid is topped off. Is there a sensor that needs to be reset. thanks
Old May 27, 2015 | 03:41 PM
holiday's Avatar
2003 xj8 hard body. engine coolant light stays on. car does not run hot. has coolant in it. trying to find the cause. any help would be appreciated. thanks
Old May 27, 2015 | 04:16 PM
Fraser Mitchell's Avatar
Is your car the aluminium X350, or the steel X308 ? 2003 was the changeover year, in fact, I don't think any X350s got to the US and Canada until 2004, but I may be wrong.
Post in the X308 if it's the steel car. However, if the coolant level is correct, it sounds like a duff level sensor in the header tank.
Old May 27, 2015 | 04:43 PM
holiday's Avatar
Its the x308 hard body steel. thanks
Old May 27, 2015 | 05:06 PM
Don B's Avatar
Hi holiday,
I have moved your thread from the forum for the X350 to the forum for the X308.
Cheers,
Don
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
TC Johnson
Sep 2, 2015 09:30 AM
daro31
Aug 27, 2015 09:26 AM
