Engine Vibration
Old Apr 28, 2008 | 07:53 PM
jag_genius's Avatar
Default RE: Engine Vibration
not really normal..you can unbolt your torque converter.. and turn it 1/3 and rebolt it and see if it goes away..
Old Apr 29, 2008 | 07:51 PM
jag_genius's Avatar
yes sounds like someething is out of balance have had it on newer xj's.. not really drive train since it does it when at a stop
Old Apr 30, 2008 | 08:10 PM
jag_genius's Avatar
everything in drive line is balanced by itself and shud work together with no balance problems.. had a torque converter out of balance and when moved it then bolted it up it got better so i replaced the torque converter and it was gone..
if it's slight dont really think it can do any damage.. but have also seen an engine out of balance internal parts out of balance.. which dint really do any damage just annoyed the customer.. never seen a timing chain have a vibe.. unless it rattles like crazy and it 's about to blow.. any noise form chain area.. ?
Old Apr 30, 2008 | 08:11 PM
jag_genius's Avatar
hard to tell without actually driving the car.. something like that has to be felt... to diag it.
Old May 2, 2008 | 07:18 PM
jag_genius's Avatar
it may be a misfire starting.. chains usually dont give vibrations..
SD96XJ6L
Jan 12, 2022 04:30 AM
GordoCatCar
Jan 2, 2017 01:10 PM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
