Failsafe Mode on right hand turns
Old Sep 29, 2012 | 02:40 PM
hexemom's Avatar
Default Failsafe Mode on right hand turns
my 99 VDP has 67K miles on it and she is new to me. it's been going into failsafe mode intermittently ALOT. we have TSP error codes, but i've been noticing 9 times out of 10 when failsafe engages it is when i make a right hand turn. the throttle body is clean and looks to have been replaced. when it goes into failsafe i have no option but to pull off the road and restart and hope for the best. it would take half a day to get to speed limit in failsafe mode. sometimes it will misfire when entering into failsafe mode and the engine light comes on. sometimes the transition is smooth. any ideas?
thanks!
gloria
Old Sep 29, 2012 | 04:06 PM
hexemom's Avatar
also, ASB light and stability control light is on.
thanks for any ideas
-gloria
Old Sep 30, 2012 | 05:28 AM
Sean B's Avatar
Possible failing battery - can you post the codes? is that TPS codes, i.e. throttle position sensor?
Old Oct 1, 2012 | 08:09 AM
hexemom's Avatar
The battery is brand new, got it and the alternator checked and they are working fine. I can't remember the number for the code but yes, it was for Throtle Position Sensor failure.
Old Oct 1, 2012 | 08:19 AM
steveinfrance's Avatar
Dirty ABS sensors or loose wiring to them?
Old Oct 1, 2012 | 11:47 PM
pdog2000's Avatar
what he said
Old Oct 14, 2012 | 10:36 PM
jun67w's Avatar
Smile failsafe mode
I have a '99 XJ8 with the same problem. After a replace the battery with a new one, the problem appears to be gone.
Old Oct 15, 2012 | 10:00 AM
hexemom's Avatar
seems like we've narrowed it down to the ABS sensors. thanks for all the suggestions!
Forcedair1
Sep 8, 2025 01:57 PM
Adam Lueb
Sep 28, 2015 02:54 PM
Richard_gib
Sep 12, 2015 07:08 PM
Saturbo
Sep 8, 2015 07:35 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
