Fuel Filter Replacement 1999 VDP
Old Feb 19, 2024 | 09:13 AM
Larry_in _Missouri's Avatar
Default Fuel Filter Replacement 1999 VDP
Are there any "tricks" or hints for replacing the fuel filter on this model. The filter is near the bottom of the fuel tank but above exhaust and stabilizer members which makes getting a wrench on each end to stabilize the filter while removing the fuel line next to impossible. Does anyone have any special recommendations or specific tools which make the job easier? By the way, mine is the early version with screw type fuel line fittings, not nipples and clamps.
Old Feb 19, 2024 | 09:16 AM
Quadcammer's Avatar
Stubby wrench may help, but it's really not too bad even without. Obviously helps if you have skinny hands and arms
Old Feb 20, 2024 | 09:18 AM
motorcarman's Avatar
16mm and 20mm open end wrenches and a little fuel in your armpits, then you are good to get the new one in place.
I always 'twirl' the old filter before I try to remove the lines so the 'O'rings release.
Old Feb 23, 2024 | 07:09 AM
cjesse444's Avatar
Does anyone know the size of O rings for filter. They don’t include with filter and want to just get from parts store locally. Thanks
johnsjag
Sep 22, 2014 10:17 PM
Jaguila
Jan 20, 2014 08:01 PM
plums
Jun 19, 2012 07:06 PM
cbgbglavan
Mar 16, 2011 02:52 PM
Adam Lueb
Oct 14, 2010 04:11 PM
