fuel injector cleaner
Old Dec 22, 2008 | 12:10 PM
leexjr's Avatar
Default fuel injector cleaner
I've just collected my car from the mot station and lucky for me no major problems although they saidwhendoing the emissions testthe there is alot of carbon from me doing short tripsand advised me to put some injector cleaner into a full tank of fuel.
what with them not being jaguar experts iwanted some advice really on what brand i should use & if i should be putting this into my xjr? i know STP make one.
thanks
lee.
Old Dec 23, 2008 | 10:25 AM
skanoski's Avatar
Default RE: fuel injector cleaner
I think Lucas has one of the better ones. That's what I always use.
Old Dec 23, 2008 | 10:27 AM
Doug's Avatar
I think Lucas, Techron, and BG are good.
I'd suggest having the injectors professionally cleaned at a shop using the "MotorVac" or similar method and then using the pour-in-the-tank stuff a few times a year to help keep them clean
Old Dec 23, 2008 | 05:33 PM
Cerberus's Avatar
+1 to having them done right, then keeping them clean.
I use Chevron Supreme 100% of the time. This helps keep the system cleaner.
I know Techron is a good, proven product. I believe STP's is as well. Not really familiar with the other ones.
Old Apr 28, 2010 | 08:02 AM
shl1980's Avatar
Hi,
I have access to a ultrasonic cleaning device. I plan to use that to clean my injectors.
Now, is it a good idea? And a second question: What cleaning liquid to use?
Thanks.
Old Apr 28, 2010 | 10:58 AM
Gus's Avatar
Gus
Using a good fuel and proper maintenance is a key to keeping the injectors clean. As for removing them cleaning and then reinstall I think that is excessive and not necessary unless you have a reason. As for cleaners, I have been using them from the time I started driving and that has been a long time. Today my primary choice of cleaner is BG 44k. I have been using it for several years with positive results, I should also mention that Jaguar along with other dealerships use it in my area. As for the Techron I have used it and if 44k was not available I would recommend it without hesitation. However you are the one that needs to be satisfied with the product. Either one you will not go wrong!
Old Apr 29, 2010 | 06:38 AM
test point's Avatar
Not sure if an ultrasonic cleaning device would have the same result as the normal method of forcing a cleaning product through the injector. Let us know.
Old Apr 29, 2010 | 11:33 AM
shl1980's Avatar
Well, will see, one obvious thing is, that the injectors will be in "closed" position during cleaning ... I haven't figured out that part yet ...
Old Apr 29, 2010 | 11:46 AM
ken@britishparts.com's Avatar
Don't over think it. The BG 44k is good stuff. Burn some periodically. These cars don't go through injectors like the old XJS and Series 3 cars did.
knightofgold
Feb 11, 2016 06:03 PM
ogorir
Jan 18, 2016 10:09 PM
Bigvettefreak
Sep 29, 2015 04:13 PM
ratgawd
Sep 16, 2015 04:15 PM
Bcrary3
Sep 11, 2015 10:36 AM
