Grinding noise at idle
Old May 9, 2018 | 02:57 PM
AZjag1999's Avatar
Default Grinding noise at idle
Hello, all
I've been posting quite often lately due to some work I've done on my 99 XJR. I had the supercharger off and changed the oil and put in a solid coupler. It seems that every time I'm at idle while in gear, there is a grinding-like noise from the engine. I belive it to be from the supercharger because I can hear it come from that general area. If I am in park or neutral, the grinding noise goes away. If I put it in reverse or drive, the grinding noise comes back. If i am in drive or reverse and i rev it above idle, the noise goes away. So only at idle when I'm in gear, does it do that. I put a new belt on with the correct size and did not change the sound at all.
Any ideas?
Should it be of serious concern?
Here are some videos but they don't really capture the sound:
https://drive.google.com/file/d/1bQ-...w?usp=drivesdk
https://drive.google.com/file/d/1phs...w?usp=drivesdk
https://drive.google.com/file/d/1iIK...w?usp=drivesdk
Thanks.
Old May 9, 2018 | 04:26 PM
Robman25's Avatar
Try to track down the noise with a mechanics stethoscope or at a pinch a long screwdriver.
I have much the same noise from my s/c and just live with it at the moment. Too many other things going on in the home garage (‘65 ‘S’ being rebuilt)
Old May 9, 2018 | 11:33 PM
M. Stojanovic's Avatar
I understand that the grinding noise came after you did the work on the supercharger and was not present before. If this is the case, then it could be caused by the solid coupler. I have read that solid couplers (maybe not all) will make the supercharger noisier but there was no description of what kind of noise this will cause. The way to diagnose is to remove the SC belt and run the engine.
Old May 10, 2018 | 09:59 AM
Highhorse's Avatar
I had a similar noise last Spring and it was one of my neoprene seconary tensioner caps that had decided to visit the oil pan and the chain was rolling across the metal nub. It would usually happen under load. I thought it was my SC, since I had recently done the oil and that's where the noise seemed loudest. It was my passenger side one.
+1 on the stethoscope (which is how I found it) and another +1 on the belt ideas.
Old May 10, 2018 | 11:48 PM
AZjag1999's Avatar
If I get the chance, I'll do what has been suggested, but since it's only there at idle when in gear, I doesn't bother me much. Good suggestions though.
Thanks.
Old Jul 17, 2018 | 07:35 PM
AZjag1999's Avatar
Just to follow-up with this:
I changed the solid coupler I had to the original torsion coupler that was originally in there (new of course), and the noise is not there anymore.
If anyone has similar issues, then i would recommend checking the condition of the coupler.
Old Jul 20, 2018 | 04:29 AM
Datsports's Avatar
Hello, all
Any ideas?
Thanks.
its gear chatter. See here
https://www.jaguarforums.com/forum/s...ads-up-176686/
Old Jul 20, 2018 | 11:59 AM
JTsmks's Avatar
Don’t use the green, grey or black solid couplers as they are LOUD and offer no give, use the white urathane one available on Ebay, it has a little “give” and is WAY quieter then the stock or the grey/green/black rock hard ones. Believe me, I’ve done the trial and error work on this.
Old Jul 20, 2018 | 08:19 PM
Z07Brandon's Avatar
Glad to see you found the culprit man!
jhxj6
Sep 24, 2019 10:59 AM
2xlooser
Aug 18, 2011 08:20 AM
elardizabal
Jun 11, 2009 04:11 PM
jhamrick
Jan 26, 2008 11:19 PM
