HELP! Mystery rough idle problem has us baffled!
Old May 17, 2012 | 10:02 AM
jimlombardi's Avatar
Hi
Here is an email reply I received from NGK UK Technical:
Re: NGK 5464 Spark Plug (BXR5EIX-11) product fit for 2001 XJ8 4.0L -also its ohms tests range
Dear Jim,
BKR5EIX-11 (Stock code 5464) is perfectly suitable to be used in a 2001
4.0 XJ8 as an upgrade over the recommended spark plug.
This plug has a resistance value of 5kOhms.
Different markets can have different recommended items and our UK
partfinder site is relevant for the UK market vehicles only.
Thank you for your enquiry.
Regards,
Mik Peirce AffIMI
Technical Assistant
NGK Spark Plugs (UK) Limited
Maylands Avenue
Hemel Hempstead
Hertfordshire
HP2 4SD
Tel: 01442 281000
Fax: 01442 281001
Website: www.ngkntk.co.uk
To: techweb@ngk.co.uk,
Date: 17/05/2012 13:41
Subject: NGK 5464 Spark Plug (BXR5EIX-11) product fit for 2001 XJ8
The email reply covers the acknowledgement that the NGK 5464 is perfectly suitable to be used in a 2001
4.0 XJ8 as an upgrade over the recommended spark plug. And the ohms resistance is 5k for this spark plug.
Jim Lombardi
Old May 17, 2012 | 02:17 PM
SirJag's Avatar
Originally Posted by limelight
There are several things that need to be checked that have not been so far. First is compression test, as well as fuel pressure tests, and injector flow tests. I would start with fuel pressure as it is the easiest, followed by the compression test, and then the injectors.
Thanks, Limelight.
Do you (or anyone else) happen to have fuel-pressure specs for a 2001 VDP? Both key-forward and engine running?
If so, would you kindly post? I've actually started a new thread about fuel pressure to help others looking for this topic, as I didn't see an existing one.
Thanks so much!
SirJag
Old May 17, 2012 | 02:20 PM
SirJag's Avatar
Originally Posted by jimlombardi
Hi
Dear Jim,
Regards,
Mik Peirce AffIMI
Technical Assistant
Maylands Avenue
Hemel Hempstead
Hertfordshire
HP2 4SD
Tel: 01442 281000
Fax: 01442 281001
Jim Lombardi
Thanks a lot, Jim. A guy from NGK asked me to call him... says he has some explanation. I'll post what I learn. I appreciate you looking into this. Odd, still, how some sites--like Amazon, as one example--specifically says they are NOT right for the VDP.
More soon...
SirJag
Old May 17, 2012 | 02:22 PM
SirJag's Avatar
SirJag
Have you removed any of the spark plugs too see if they fouled with oil?
When you had the ignition coils out, did you noticed any oil around the spark plugs (the Valve Cover Spark Plug Seals may have failed).
Just another possible issue that may cause the misfire DTC codes.
Jim Lombardi
Hi Jim:
Yes, this was done. None were fouled, yet there wasn't a nice white "ash" on those plugs. My tech is heading in the "fuel pressure" direction right now. Theory is that cyls 7 & 8 are last on the fuel rail... and the last to get fed... so maybe the fuel pump is the problem. Brutal suggested to swap fuel injectors, so that's next.
Thanks so much for posting those docs!
Update soon.
SirJag
Old May 18, 2012 | 08:02 AM
limelight's Avatar
Fuel pressure on most cars is between 32-42 psi key on, engine running. Fuel pressure should go higher with key on engine off, and when accelerating.These specs should get you in the ballpark.
Just make sure the fuel pressure does not go down when accelerating.
Cheers!
Old Nov 28, 2018 | 01:57 AM
Disco1994's Avatar
Hi, SirJag. Have you found any resolution to this problem? I am seeing very similar issues on my 1999 VDP NA.
Old Nov 28, 2018 | 10:05 AM
Jhartz's Avatar
Sir Jag has been long gone from this forum; last I saw was back in 2014 or so. This thread is six years old.
Maybe he is still reading on the forum . . . ?
Might try to open a new thread . . . In the meantime, what codes? Have you cleaned the MAF sensor; the throttle bore and plate; checked for air/vacuum leaks along the air tube; replaced the plugs; and most importantly (imi most importantly), have you replaced your secondary tensioners (out of time was probably Sir Jag's issue)?
Old Dec 2, 2018 | 06:29 PM
  #28
Disco1994's Avatar
Thanks for your reply Jhartz.
I found my issue this week. I replaced plug and coil on cylinder 5 (1B) and it solved my issue.
I will try to put together a full write up on the problem and why I had so much trouble diagnosing it and then post a new thread and link to it here.
Old Nov 22, 2022 | 08:39 PM
Life And Projects By Austin YOUTUBE's Avatar
@SirJag was this ever resolved?
Old Nov 25, 2022 | 09:55 PM
  #30
RandyS's Avatar
He no longer posts in this forum.
GordoCatCar
Jan 2, 2017 01:10 PM
Daim
Nov 28, 2016 09:28 AM
Thang Nguyen
Oct 12, 2015 01:25 AM
joesoap
Sep 10, 2015 01:09 AM
Bowman
Sep 3, 2015 03:17 PM
