Help, New to Jags!!
Old May 30, 2019 | 08:38 AM
XJRMan2005's Avatar
Default Help, New to Jags!!
Hello, I just bought a 2003 XJ Super V8 LWB, I believe with all testing to be a fuel pump issue, I owned a 2001 XJR that had 2 pumps and a return line. What I need to know is what the right pump is for the Super V8, as it has only one pump, correct?
Old May 30, 2019 | 09:01 AM
Sean B's Avatar
If as you say it's a Super, then it should be supercharged, so 2 pumps, same as the R.
Old May 30, 2019 | 09:17 AM
XJRMan2005's Avatar
It is infact a Super, so when I look up for parts I do not see a kit with 2 pumps, can you share links or part numbers by chance?
Old May 30, 2019 | 09:25 AM
M. Stojanovic's Avatar
If it has a supercharger, just buy fuel pumps for X308 XJR.
Old May 30, 2019 | 09:42 AM
XJRMan2005's Avatar
SAJDA25B53MF58223 is the vin# parts stores are worthless, as they seem to not carry the right pumps.
Old May 30, 2019 | 04:51 PM
Addicted2boost's Avatar
Since you just bought this car and if time isn’t an issue, I would strongly recommend purchasing Denso fuel pumps. 950-0172. You will have to use the adapter wiring harness that’s supplied with these pumps. I just replaced both of mine last night. In my opinion Denso components are at the top when it comes to quality. I bought mine from Amazon and were $152 shipped for both of them. If time is an issue and you need them real quick then Airtex is next one down and I believe parts stores have that brand in their inventory. I’d also replace the inline fuel filter for good measure as well. The Denso pumps I listed above have the fuel sock that attaches to the bottom of the pump included with that part number.
Old Jun 1, 2019 | 09:06 AM
RA110623's Avatar
Banned
if you will buy after market brand it will need some modifications once you get the pump out I got Delphi fuel pump it comes with all hardware you need but I didn't know that denso can fit also get the denso it can last for 10 years . I think it's 75$ in Amazon or rock auto . denso part number 950-0172
Old Jun 4, 2019 | 01:35 PM
XJRMan2005's Avatar
Thanks, pumps are in, now I just have to fix the fuel line leak issue.
Jaggernaut3
May 8, 2019 12:06 PM
BlownBrit
Dec 15, 2015 06:46 PM
buckytomsk
May 26, 2014 02:51 AM
JaggyUK
Jan 2, 2012 02:27 PM
vicjag
17
Jul 17, 2007 02:16 PM
