hesitation
Old Feb 26, 2008 | 08:11 PM
ey_shyguy's Avatar
Default hesitation
ok, i've already read smx's forum on this, but is this a common problem???
2 people said it already, an at 3-4000 rpm, its happenning to me too. car just hesitates. fuel line under the hood sounds like to rare of a problem for so many people with same problem....any suggestions???
Old Feb 26, 2008 | 08:17 PM
FactoryJaguarTech's Avatar
Default RE: hesitation
sthesitation? No other indication of trouble? Check engine light?
Model, engine size, miles etc would be helpful.
Old Feb 29, 2008 | 06:23 PM
ey_shyguy's Avatar
no engine light, or any other problems. just when passing another car, car hesitates between 3000 rpm and 4000rpm.
1998 xjr 4.0 supercharged
Old Feb 29, 2008 | 06:51 PM
jag_genius's Avatar
i wud check the fuel pressure regulator vacuum line right side of engine beside the throttle body.. rightoff the regulator the vacuum line makes a 90 degree bend and in that bend it collapses over time cause vehicle to be too rich.. sometimes does not set codes.. unless if it is severe.
Old Feb 29, 2008 | 08:51 PM
ey_shyguy's Avatar
i just realized that a part of my air intake hose, between sensor and throttle body, has duct tape around a crack in the hose.
could this cause the hesitation?? where can i get this hose from??? can't find any online.
Old Mar 1, 2008 | 06:30 PM
That would definitly do it. If it is hose going from intake tube to bank 1 cam cover gasket, it is called the full load breather hose. I think it is only about $20.00 or thereabouts at dealer.
Old Mar 2, 2008 | 10:05 AM
jag_genius's Avatar
if you talking about the regulator hose having the duct tape on it.. it needs to be replaced.. any jag dealer has the piece .. $5-10
Old Mar 2, 2008 | 01:17 PM
lol.....take a picture and post it so we can settle this once and for all!!
Old Mar 2, 2008 | 02:47 PM
ey_shyguy's Avatar
good idea. i'm really new to this. sweet forum.. love this site,,,thax again
[IMG]local://upfiles/3252/CE342631EE60491ABD76B887C674F0B6.jpg[/IMG]
Old Mar 2, 2008 | 09:14 PM
That is like a damper on the intake tube. If it is leaking, will cause unmetered air access to the engine. Could cause the issue. Always fix the obvious first.
Old Mar 2, 2008 | 09:34 PM
ey_shyguy's Avatar
where should i get the hose from???dealer only???
Old Mar 3, 2008 | 04:46 AM
Wouldnt surprise me if it was only available on the intake as assembley.
Take off the duct tape and see what is going on with the one you have. Maybe you can repair?
Old Mar 16, 2008 | 08:35 PM
ey_shyguy's Avatar
hey guts thanx for all the help.. anyway, i repaired the pipe today, but hesitation is still there. should i do throttle body cleaning first? fuel system cleaning?
i saw that so many others have the same problem, but all had different solutions.
thanx again
Old Mar 17, 2008 | 04:31 AM
I would take off the coil covers and make sure the coil connectors arent broken too.
Old Mar 17, 2008 | 04:33 AM
In fact, while you are there, remove coils and see if they are covered in oil.
Also pull the plugs out and have a look at them.
Old Mar 17, 2008 | 06:23 PM
jag_genius's Avatar
you guys still dint verify the fuel regulator vacuum hose is ok
Old Mar 17, 2008 | 09:14 PM
ey_shyguy's Avatar
I WILL CHECK IT ASAP AND LET U ALL KNOW. IS IT THAT COMMON A PROBLEM THOUGH? I ASKED MY MECHANIC AND HE SAID ITS UNLIKELY. BUT I TRUST U MORE..THANX
Old Mar 18, 2008 | 04:53 AM
lol.....I always assume that vacuum leaks are checked first. Forget that I am talking to people that don't do this for a living.
Dave1109971
Dec 15, 2015 06:16 PM
Feffman
US Lower Atlantic
Sep 29, 2015 01:38 PM
javenlevi
Sep 22, 2015 03:37 PM
VRB
Sep 15, 2015 08:18 AM
AtholC
Sep 9, 2015 09:07 PM
