Horrible Annoying Rear Suspension Clunk
Old Jun 6, 2018 | 11:27 PM
omgimali's Avatar
Default Horrible Annoying Rear Suspension Clunk
This clunk drives me insane. its steady on the most smoothest road if you're doing 55mph and its horrible on the smallest bumps on the road. Especially how horrible the roads in south carolina are. tires are wearing inside. Can anyone pinpoint the problem?
Old Jun 6, 2018 | 11:41 PM
CharlzO's Avatar
Could be a few things back there, but tires wearing on the inside indicate something isn't sitting right. It sounds like it's got a bit of a clank to the clunk as well. Jack the car up, wheel off the ground, and press in on the top, bottom, left and right of the wheel and see if there's any movement in either way. If it's wearing on the inside, I'm inclined to think there might be excessive play in the outer u-joint of the halfshaft. If you are able to push the wheel in on any of the corners, have someone press on it while looking at the backside. I'll link a video that shows mine that shows exactly what I mean. Bear in mind, mine is excessively bad, but you'll get an idea of what I mean.
It could also be something in the upper shock mount area, but the only way to know would be to pull the shock out altogether, which takes a little more time and steps. I suppose if it broke enough up there where the shock wasn't being supported properly, then it could cause the shock itself to raise too high while it was sitting, and therefore letting that side "squat" more than it should, leading to inner tire wear.
Old Jun 7, 2018 | 12:06 AM
omgimali's Avatar
It is squatting down to the right side which is where most of the noise is coming from. something leads me to believe me that it has something to do with the Shock assembly. I'm going to jack the car up tmrw and check
Old Jun 7, 2018 | 11:33 AM
CharlzO's Avatar
That's what clued me into mine as well. I had a slight clunk sometimes shifting forward to reverse from that corner, but otherwise, hardly made a peep (or my radio was up too loud to notice it). Hopefully it'll be easy to spot whatever your issue is.
Old Jun 7, 2018 | 03:08 PM
omgimali's Avatar
I think those upper mounts are about gone
Attached Thumbnails Horrible Annoying Rear Suspension Clunk-img_0544.jpg   Horrible Annoying Rear Suspension Clunk-img_0545.jpg   Horrible Annoying Rear Suspension Clunk-img_0546.jpg   Horrible Annoying Rear Suspension Clunk-img_0547.jpg   Horrible Annoying Rear Suspension Clunk-img_0548.jpg
Horrible Annoying Rear Suspension Clunk-img_0549.jpg   Horrible Annoying Rear Suspension Clunk-img_0550.jpg   Horrible Annoying Rear Suspension Clunk-img_0551.jpg
Old Jun 7, 2018 | 04:33 PM
CharlzO's Avatar
Certainly looks like a viable culprit!
Old Jun 8, 2018 | 11:02 AM
omgimali's Avatar
hmmmm, so i would need to replace the shocks and upper shock mount bushings?
Old Jun 8, 2018 | 11:13 AM
M. Stojanovic's Avatar
Your shocks may still be good (mileage?) but you certainly need to replace the three foam "doughnuts" (small, medium and large) at the top. Another source of knocks can be the shock lower bushings which you can inspect when you have everything out.
Old Jun 8, 2018 | 03:46 PM
King Charles's Avatar
I'd just replace everything(minus the spring) shock related whilest there.
Old Jun 8, 2018 | 08:16 PM
omgimali's Avatar
94,220 miles
gotta change the signature
Old Jun 8, 2018 | 08:17 PM
omgimali's Avatar
and what all do i need for that?
Old Jun 8, 2018 | 09:13 PM
https://www.jaguarforums.com/forum/x...8/#post1389438
The upper spring isolator is P/N MMD3565AA ordered off Ebay for $36 each.
The upper shock isolator is P/N CAC949350 ordered from Motorcars LTD for $9.05 each plus shipping.
The lower shock isolator is P/N CAC949465 ordered from Motorcars LTD for $16.53 each plus shipping.
The bottom shock mount is P/N CCC6782, but I didn't replace mine as they didn't look bad and can be replaced on the car if need be. The shocks are original and new shocks come with new lower shock mounts, so I didn't think it was worth it.
Old Jun 8, 2018 | 09:17 PM
If you buy new shock absorbers (#7, you can choose comfort or sport), they will come complete with two smaller foams at the top so you will only need to add the items 4 and 5 shown on the diagram.
Old Jun 8, 2018 | 09:19 PM
https://www.jaguarforums.com/forum/x...03-xjr-147998/
Old Jun 10, 2018 | 07:52 PM
Carnival Kid's Avatar
Omgimali, this link may help too...................
https://www.jaguarforums.com/forum/x...-video-201680/
Old Jun 11, 2018 | 05:52 PM
D. Fite's Avatar
I had a thumping problem similar to your a few years ago. It turned out to be the upper shock nut was loose. I found this because I replaced the shocks thinking it was bad.
Old Jun 11, 2018 | 11:17 PM
omgimali's Avatar
How hard was it to tighten?
Lawrence
XJ40 ( XJ81 )
Feb 2, 2015 09:36 PM
Lawrence
Oct 4, 2014 02:21 PM
mercedes60
Mar 17, 2014 01:01 PM
JWT
Jul 6, 2010 03:57 AM
Frankie
XJ40 ( XJ81 )
Apr 13, 2009 01:31 PM
