How to put a 2001 xjr engine into a 1998 xjr
Old Oct 2, 2016 | 12:45 PM
Dhighlife27's Avatar
Default How to put a 2001 xjr engine into a 1998 xjr
Hi all. I recenctly took on a big project for the first time and i am also very new to jaguars. I have a 1998 jaguar it had a blown head gasket so i put a new engine in from 2001 jaguar xjr . The engine went in just fine ,but woulnt start. I know i either need to take some of the parts from the old engine and put them on the new one , or get ecu/pcm/immos ect... from a 2001 but im not sure what i need to do. Please let me know what i need to do to make it run thank you.
Old Oct 2, 2016 | 01:14 PM
motorcarman's Avatar
Old Oct 2, 2016 | 02:43 PM
Thank you those links helped out alot , when i replace the intake camshaft on bank b ( drivers side correct? ) how do i know which one to swap? Or do i swap both? Also why do i only need to swap that one ? Is there any way to leave it in and simply ajust it ?
Old Oct 2, 2016 | 06:00 PM
I NEVER say Driver's or Passenger's without qualifying which Country that you are talking about.
Ask someone in the UK or Australia which is the driver's side??????????
You need to keep reading and understand all the differences between the engines.
All the Intake Cams have a different number of lobes for the CMPS for the different Engine Management systems.
bob
Old Oct 2, 2016 | 10:00 PM
xjay8's Avatar
Ask someone in the UK or Australia which is the driver's side??????????>>>>
......>>>>>> bob
G'day Bob.....I had to have a quiet chuckle over this ;o)
The Pom's make it more difficult for us all by calling the RHS the 'near side'
and the LHS the 'off side'.....(all positions as seen from the drivers seat)
And you lot confuse things even more by calling a car manufactured in '98
a '99 model and so on.....we're simple folk down here and like the KISS principle ;o]P
Old Oct 2, 2016 | 10:50 PM
xjay8's Avatar
zip 'o]P
Old Oct 3, 2016 | 03:13 AM
clifton94's Avatar
RHS is the offside LHS is the nearside from the drivers seat in the uk ����
Old Oct 3, 2016 | 04:23 AM
xjay8's Avatar
Hahahaa....thanks for correcting that Clifton....trust me to get it **** about! ;o]P
Old Oct 4, 2016 | 03:55 AM
clifton94's Avatar
No problem you know us brits are here to put the world to rights lol ��
Old Oct 9, 2016 | 07:14 PM
Ok just to be sure i am in the USA , so which side is bank b , and also should i only replace the inlet camsaft on bank b or can i replace both inlet camshafts . Aslo if someone could provide pictures of be vary detailed it would be apriciated.
Old Oct 9, 2016 | 08:07 PM
joeleerj
24
Sep 14, 2016 07:47 AM
JagXFiRst
Sep 10, 2016 07:48 PM
UncleTom
US Western
Sep 8, 2016 12:06 PM
jandouglass
Sep 5, 2016 11:55 AM
Adamce
Sep 4, 2016 06:36 PM
