I'm excited :-)
Old Dec 18, 2012 | 05:25 PM
richard thomas's Avatar
Default I'm excited :-)
....my new front suspension/subframe/steering bush kit parts arrived today (xmas present to myself)....looking forward to tearing the front out to finally lose the annoying knocking....but wish it wasn't quite so cold to lie on the garage floor for a couple of days....
Old Dec 18, 2012 | 05:45 PM
2l8and1's Avatar
I'm with you Richard, been turning wrenches in sub freezing temps myself. But well worth it anyway enjoy
Old Dec 18, 2012 | 07:55 PM
danielsand's Avatar
Awfull cold over here too. In the 50s during the day, and low 40s at night. Luckily the garage is fully insulated (all five of them), and the propane heater works well!
Just finished some work on the MBZ, and garage was cozy warm.
Get yourself one of those propane heaters, turn on the music, make sure you have plenty of good German beer (may I suggest "Franziskaner"?), and go to town on it! Good luck.
Old Dec 18, 2012 | 08:08 PM
Safi's Avatar
ive got an insulated garage as well, but i simply use a radiator heater, it gets the garage up to about 65 i think, might have to try the propane heater as Daniel recommended, but the cold weathers put you in a tiresome mindset making you not want to do anything. i have to get my timing covers off, but simply have no motivation to do it, its depressing looking at the cat sitting in the garage
Old Dec 19, 2012 | 02:53 AM
I will try to take some pics as I go through it.....no doubt the job will get bigger than I expect....I have a feeling I will be breaking out the welder at some point for the front chassis rail behind the shocks...
Old Dec 19, 2012 | 03:45 AM
Highway Star's Avatar
Default "
May the Force be with you, Rich.
Old Dec 19, 2012 | 03:49 AM
Originally Posted by richard thomas
........but wish it wasn't quite so cold to lie on the garage floor for a couple of days....
Wimp!
Good luck - it'll be worth the work.
Old Dec 19, 2012 | 06:40 AM
rocklandjag's Avatar
The hardest part for me when I replaced all of the everything was getting the old bushings out. I found that pressing out the center sleeve first and then carefully cutting a notch into the outer sleeve was a huge time saver. I used a jigsaw and worked slowly so as not to cut into the control arms. Once the notch is cut i used a cold chisel to bend in the sleeve and then they popped right out
For the ball joints you need to cut off most of the top flanges in order to get enough surface area on the control arms for a tube/socket to seat without angling off underr pressure. The ball joints are are in really tight and it sounds like a gun shot when they finally give
Good luck with the project
Old Dec 19, 2012 | 04:58 PM
Thanks, will bear that in mind.....
Will keep you all posted (with pics for Sandy)...lol
Old Dec 19, 2012 | 05:20 PM
dsnyder586's Avatar
Danielsand is right- it has been bitterly cold here- I think we saw 32 in some spots. Thank goodness we are back to 70 during the day!
I prefer "Dutchie" beer myself- no preservatives!
Old Dec 19, 2012 | 07:10 PM
Safi's Avatar
during the cold winters a nice pint of Boddingtons hits the spot, but i just bottled a batch of English Brown Ale, so in a couple weeks, ill be drinking that
Old Dec 20, 2012 | 06:10 AM
Probably do a couple of cups of tea :-)
rldvols
Oct 7, 2015 10:01 PM
DFW
Oct 1, 2015 07:22 PM
baskervillema
Oct 1, 2015 01:59 AM
Moghut
Oct 1, 2015 01:55 AM
asleach2889
Oct 1, 2015 01:53 AM
