Inconsistant operation
Old Feb 22, 2021 | 01:16 PM
Desertdawg's Avatar
Default Inconsistant operation
My '98 XJ8 has a weird issue that's comes and goes. It sometimes seems to almost default into running or starting on 4 cyl. When it that mode I can barely run it, with foot on the gas and brakes to keep the revs up. Below 1500 rpm it dies, then starts very hard. If I let it set overnight it may fire up and run fine. I think it's either fuel on one bank or maybe electrical on one bank. When it does start normally, I can run it for many miles. Any ideas?
Old Feb 22, 2021 | 01:53 PM
JagV8's Avatar
Also could be an air leak.
Old Feb 22, 2021 | 04:41 PM
Desertdawg's Avatar
Don't have a code reader for the old gal, so will take her to the shop. Wasn't running due to broken timing chain when purchased
It has codes that I can't delete, so unsure of that too. Hope the shop in Idaho figures it out this week while we're getting some sun in AZ. 😊
Old Feb 22, 2021 | 10:02 PM
NBCat's Avatar
Post the DTCs the shop finds stored in the system.
Old Feb 23, 2021 | 01:40 AM
JagV8's Avatar
+1 and make sure they tell you the actual DTC not just some wording
Old Feb 23, 2021 | 04:54 AM
Addicted2boost's Avatar
[size=16px]On the AJ26 only engines, (98’ - early 99’s) there is an Ignition module (LJA1450AF) dedicated for each bank since the coils for this engine are 2 pin only. I agree with everyone else that you need to get the codes though. Mentioning the ignition modules was a potential area of concern. [/size][size=16px](Not sure why the text is all jacked up.)[/size]
Old Feb 23, 2021 | 04:00 PM
Desertdawg's Avatar
That's very interesting. I think it could be the answer, or else something "upstream" signaling a bank to drop out. One time it sat idling smoothly for 15 minutes until I shifted out of park. It immediately died and I had to limp it home.
Old Feb 23, 2021 | 07:10 PM
Kroeger’s Jag's Avatar
Typically there would be more symptoms with this issue but maybe it’s a very very low battery?
scottpeterd
Oct 6, 2020 05:16 AM
EcbJag
Feb 11, 2019 12:51 AM
mhamilton
Jul 9, 2016 10:54 AM
Jon750rr
Mar 4, 2016 10:42 AM
times2fxp
Mar 3, 2014 11:24 AM
