Installing footrest / dead pedal: Need to drill
Old Jun 3, 2014 | 12:32 PM
Platinum XJR's Avatar
Default Installing footrest / dead pedal: Need to drill
Good morning all!
I am installing a new footrest that I made.
I will post up some pics, when I am done.
Does anyone know if it is safe to drill where
the current foot rest is?
I would like to drill exactly where the rubber
pad is, but I don't know
if there is any wiring under there.
Thanks for your help
Old Jun 3, 2014 | 12:34 PM
bigcat777's Avatar
I would like to know the same thing. I have been wanting to add a footrest also.
Old Jun 3, 2014 | 12:46 PM
Here is what I bought.
Fit for 09 Chevrolet Cruze at MT Footrest Pedal Cover Foot Rest Pad Left Hand | eBay
It's stainless steel and the rubber pads are nice.
I cut out some wood in this exact shape,
and painted it black.
Painted the wood block black and attached this pedal to the wood
using 3M emblem and trim foam tape.
I made my pedal 2.5" thick and it is VERY comfortable for me.
This pedal looks really nice and fits the footwell very well.
People in the UK must have extraordinarily long legs.
I am 6"1" and I feel like a little kid, as I cannot
reach that rubber pad for my left foot.
I hope to drill a few holes and get it mounted.
I tried using the 3M tape to mount it, but
with the new height it does not feel stable.
TIA for your advice.
Old Jun 3, 2014 | 12:50 PM
bigcat777's Avatar
Sounds good XJR. I am planning on just wood..I have some nice rare blocks I want to cut and form. Don't know how to apply, I would like to drill through and attach.
Old Jun 3, 2014 | 08:09 PM
Vector's Avatar
My pedals with the footrest or "dead pedal" custom made for my "R" insert by Ultimate Pedals, got them in a group buy I put together on the forum last year.
Vector
Attached Thumbnails Installing footrest / dead pedal:  Need to drill-20131103_173344.jpg
Old Jun 3, 2014 | 09:14 PM
Vector
I spoke with Robert at Ultimate Pedals several times.
Decided not to go with them.
Back on topic, do you know the answer to my query?
Old Jun 3, 2014 | 10:52 PM
plums's Avatar
Actually, they must be lopsided.
The dead pedal is way out there while the gas pedal is far too close.
Old Jun 4, 2014 | 02:48 PM
True!
Old Jun 4, 2014 | 06:11 PM
andrew lowe's Avatar
Could this be one of those things that do not quite work when putting the steering wheel on the wrong side ? I don't have long legs ( but they do reach the ground ) and have no problem with the position of my foot rest, it is more or less in line with the throttle pedal, but is of course on the transmission tunnel .
Old Jun 5, 2014 | 10:39 AM
poisonpill's Avatar
I'm really interested in installing a dead pedal as well. My left leg doesn't know where to go on long trips.
Old Jun 24, 2014 | 07:08 PM
Default Done.
I finally found the right dead pedal for my car.
First, I pulled off the factory rubber foot pad.
I bought a large black pedal / foot rest.
Bought some 2" thick dense closed cell foam.
Cut out the foam to match the foot rest.
Used contact cement to attach the foot rest to the foam,
and to glue the foam to the floor.
(I did a test on some scrap foam and carpet first.)
Here is the result:
I need to trim a little of the foam on the bottom of the foot rest as you can see in the photo.
Otherwise it is done.
Gluing the foot rest to the carpet with contact cement works well.
It is rock solid.
Unlike Vector, I did not want to install billet pieces to the gas and brake pedals. The gas and brake pedals are close enough and the foot well is small.
I need a dead pedal that will fit my size 13 foot.
This is nice, comfy, and does not look aftermarket.
The foot rest is 2" high, which feels right to me.
The dense closed cell foam is solid.
Almost forgot: To add some grip to the foot rest, I sprayed it with spray on bed liner. The stuff wears like iron, and gives just the right amount of "grippiness".
Attached Thumbnails Installing footrest / dead pedal:  Need to drill-jaguar6-24-14001_zps96f6ac87.jpg
Old Jul 2, 2014 | 01:00 PM
echoharper's Avatar
I went easy. I followed the advice on the thread. Used 2 inch pvc painted black as a spacer. Had to drill two new 1/4 inch holes below the original threaded holes. No problem The spacers need to be large diameter so the pedal doesn't rock from side to side . The larger diameter complete covers the carpet holes. Photos won't show anything except the original dead pedal level with the brake pedal. Easy job get 6 inch bolts I couldn't get long metric M6 as the original bolts are too short so new holes drilled.
aholbro1
Dec 29, 2024 06:46 PM
mrplow58
Jan 21, 2024 05:53 AM
danke
May 29, 2023 01:01 PM
chatmanx
Sep 11, 2015 07:17 PM
kstevusa
Sep 7, 2015 01:12 PM
