jaguar dont run help please!!!
Old Jun 18, 2014 | 03:53 PM
tankndem's Avatar
Exclamation jaguar dont run help please!!!
i have 98 jag xj8 it wont start fuses are good for fuel pump, injectors and i have spark and i just changed crank sensor when i turn it over it satrts for only 1-2 secs i could get it running when i put gas in the carb but it ran ruff i have good fuel presure and i am using 92 octane gas. i dont know where else to start looking please help
Old Jun 18, 2014 | 06:25 PM
RJ237's Avatar
There is a fuel injector relay, but I'm not sure where it is on the XJ8. Someone should be along shortly with the location. You can swap it with another relay of the same color.
When you have time please visit the new member area and introduce yourself.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jun 18, 2014 | 07:05 PM
avt007's Avatar
Welcome aboard! You'll find this to be a fun and friendly group. Dig in, poke around, and ask lots of questions.
If someone's post is helpful, please thank them using the "thanks" button.
If you have good information on a problem, please share it.
Post some pictures of your car when you can.
Old Jun 19, 2014 | 07:30 PM
margate69's Avatar
If you have a friend to help, do this.
Open the boot, remove the back panel (2 clips securing), this exposes the fuel tank. Someone can stand in the trunk and start kicking the tank. When the tank is being kicked, crank the car. If it starts for 2-3 seconds and then shuts off, you have a bad fuel pump.
Old Jun 19, 2014 | 09:28 PM
jimlombardi's Avatar
Here is weblink to 1998 XJ Vehicle Care Handbook PDF file:
https://www.dropbox.com/s/m5u2k7sm9h...20Handbook.pdf
Page 50 shows the Fuel Pump Relays in the Luggage Compartment
Also Here is illustration that shows all the relay locations:
If you right click on image and choose open link in a new tab, you will get a larger image for a better viewing.
Notice the Trunk Relays (Luggage Compartment) 2 Relays - Fuel Pump Relay 2 (XJR Supercharged) and Fuel Pump Relay 1 (Primary one).
Jim Lombardi
Attached Thumbnails jaguar dont run help please!!!-1998-fusebox-relays-locations.jpg
xjrjag
Nov 27, 2025 09:16 AM
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
rusty37
Jun 7, 2016 04:43 PM
mrplow58
Aug 29, 2015 10:44 PM
