JTIS for my 2001 XJ8 VDP
Old May 5, 2010 | 11:30 AM
xj8vdp's Avatar
Default JTIS for my 2001 XJ8 VDP
Can't contact (Christo) on Christo's JTIS Download Site.
Trying to download and access JTIS on mediafire.com (a third party cloud) to no avail.
Download issues out the wazoo. Anyone with the solution how to get there please help.
http://www.mediafire.com/?sharekey=3...e4b9ac475cdcd3
http://www.mediafire.com/?sharekey=3...d9941c0a3e731b
Thanks,
Thomas
Old May 9, 2010 | 07:01 PM
xj8vdp's Avatar
Has anybody ever been able to access these files?
Old May 9, 2010 | 08:18 PM
Gus's Avatar
Gus
Just go to e-bay and get it from them. Never had any luck with the downloads.
Old May 9, 2010 | 11:05 PM
EZfan's Avatar
Hi Thomas, if you want a copy of JTIS, pm me and I can send you one.
Old May 10, 2010 | 01:02 AM
H20boy's Avatar
Both links worked just fine for me. Even tried to start the download on one of them, sorry your browser is having trouble.
Old May 10, 2010 | 06:08 AM
test point's Avatar
I believe that I have the downloads. Send me a PM with your off-forum address and I will send to you. They come in two parts that have to be burned to a cd. JTIS is set up to only be accessed from the cd drive. I never found a way around it. Also took some time to get the Vista OS to work and have no idea how the new MS 7 OS will handle it but that would also be true with a $10 cd off ebay.
Old May 10, 2010 | 03:49 PM
pd_regan's Avatar
Hi guys,
If you copy all the files off the installation disk/s to a folder on your hard drive, and then run the install/setup.exe from that folder, you dont need to use the cd eveytime you run the program. Works for me for the JTIS and the JEPC.
Old May 10, 2010 | 09:47 PM
xj8vdp's Avatar
Default Thanks for the help!
I will be sending out some pm's, maybe I can get one to work, thanks again!!
Thomas
Old Apr 3, 2011 | 06:40 PM
ant17's Avatar
Got it dl'd OK but trying to use it causes an error and closes.
Old Apr 3, 2011 | 09:23 PM
jimlombardi's Avatar
Hi test point
How did you get the JTIS installed on your PC with the Vista operating system on it? I sent SirJag a copy of the CD and he had a problem when he tried to run setup.exe in the DA035/Disk1 folder with Vista. Here is what he said in his email to me: nothing happened at the installation step… sort of just stopped doing what it was doing.
I know the copy of the CD is ok because I did a test install on my wife's PC that has XP home edition .
Please enlight us on the steps you had to take to get it installed on your Pc that has Vista.
Jim Lombardi
Old Apr 4, 2011 | 05:25 AM
ant17's Avatar
Originally Posted by jimlombardi
Hi test point
Jim Lombardi
Just clicked on setup and it installed on my Vista HP, but couldn't get it to work after opening it.
Old Apr 4, 2011 | 05:31 AM
ant17's Avatar
So after I dl'd it I should have burned a cd, was there an ISO in there?
Thought I saw a cd icon.
The dl was 470MB.
tia
Old Apr 5, 2011 | 06:50 PM
Default I found xp_fix.exe on another later JTIS CD I have
Hi SirJag & ant17
I found another JTIS CD that I bought about 6 months. I had misplaced and I just found it this afternoon. It has an xp_fix.exe file and I copied to my JTIS folder on one of my HDs. Here is the zipped xp_fix.exe file (I had to zip this file because the exe file format is not allowed as an attachment):
xp_fix.zip
Try running it, reboot PC and then do the install again.
I found these instruction on another website:
"TROUBLESHOOTING:
If problem should occur, cease JTIS installation, then install the "xp_fix.EXE" program that is included on The JTIS CD. Then repeat installation of the JTIS program."
Jim Lombardi
Old Apr 6, 2011 | 05:16 AM
ant17's Avatar
Wouldn't that be for a machine running XP?
I have vista and & 7.
Old Apr 6, 2011 | 06:49 AM
Hi ant17
Is your vista a 32 bit or 64 bit operating system?
I found this article on the UK Jaguar forum.
"JTIS most definately will run on windows 7. I have version 1.3 running on my windows 7 desktop and laptop with no problems at all.
You need to run the installation file as administrator and it will work perfectly.
ie right click on the setup.exe file and select run as administrator.
All previous installs will need to be completely removed first. Hope this helps"
Here is the webpage link:
Jaguar Forum.co.uk • View topic - JTIS ????
Hey - give it a try - this might be the easy solution to getting it running in windows 7!
Jim Lombardi
Old Apr 6, 2011 | 08:58 AM
Hi ant17
I also found this article in the CNET forum on CNET.com:
Post 11 of 15
Re: Yur System32 problems
by Tufenuf - April 10, 2005 8:02 AM PDT
In Reply to: Re Yur System32 problems by ecanuck
ecanuck, If you're having this problem "16 bit windows subsystem" you could go to the link below and download "XP_Fix.EXE".
"This installaton program will reinstall the missing or corrupt Windows XP system files command.com, autoexec.nt and config.nt. The absence or corruption of one or more of these files causes a "16 Bit Subsystem" error.
We recommend that you download this file and save it to your desktop or to another location where you can find it. Double click on the file to run it once it's downloaded. If problem reoccurs in the future, simply re-run this program".
Here is the webpage link to CNET forum posting (see post #11):
http://forums.cnet.com/7723-6142_102-97312.html
Jim Lombardi
Old Apr 7, 2011 | 05:09 AM
ant17's Avatar
Hi ant17
Jim Lombardi
32 bit
Old Apr 7, 2011 | 06:07 AM
DavidN's Avatar
Did you install the Microsoft DAO (database system, included on the JTIS CD)?
I use JTIS on Vista Home premium 32 bit and after the DAO installation JTIS worked!
Old Apr 7, 2011 | 08:09 AM
Hi David
SirJag was able to get JTIS working properly early last night when he realized he was getting a DAO error. Then he ran the DA0 setup.exe (again) and that fixed it. SirJag has Vista 32 bit on his PC.
aholbro1
Dec 29, 2024 06:46 PM
hamilton7550
Jul 30, 2021 11:29 PM
picard
Oct 12, 2015 11:56 AM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
wcourt3010
Sep 9, 2015 04:34 PM
