Map sensor circuit malfunction dtc
Old Dec 1, 2009 | 07:39 AM
johnleavitt's Avatar
Default Map sensor circuit malfunction dtc
For the next guy who has this issue,
I got a cel, and pulled a map sensor circuit malfunction code. The car ran fine, so it seemed, but I did notice a 20 percent decrease in fuel economy. l looked at the stored data in my obdii reader to see that the map sensor showed 27.2 inhg, with no change due to rpms.
I looked for the map sensor to no avail, but came across a detached vaccuum line to the rear of the engine. It was fixed with a small clamp. There are a few electrical switches attached to the firewall, one of which has a nipple for a vaccuum line. I hooked the line up, and checked the reader data again. The cel reset, and life is good. I guess the switch the vaccuum line hooked up to might be the map sensor. I don't know and don't care......
Old Dec 1, 2009 | 09:18 PM
sparkenzap's Avatar
Thanks John!
Old Dec 2, 2009 | 09:58 AM
H20boy's Avatar
John, for future searches, can you post the actual DTC code you received? Glad it was an easy fix bud.
Old Jun 21, 2012 | 01:17 PM
pdog2000's Avatar
it was probably a P0105 which is exactly what i have going with the MAP sensor...i just had my octopus hose changed and i bet they forget to hook the vacumm hose back up...hope that fixes my issue too
Old Jun 22, 2012 | 09:38 AM
pdog2000's Avatar
the vacuum tube that is supposed to connect to the bottom of the MAP sensor was disconnected....i reconnected so my problem has been solved...see attached for pics of the infamous MAP sensor...
Attached Thumbnails Map sensor circuit malfunction dtc-map2.jpg   Map sensor circuit malfunction dtc-map.jpg
Old Jun 23, 2012 | 09:38 AM
jimlombardi's Avatar
Hi
Your photo of MAP sensor looks like it is somewhere near and under the windshield wiper motor. Is the MAPS (Manifold Absolute Pressure Sensor) only on the XJ Supercharger models?
Jim Lombardi
Old Jun 25, 2012 | 12:50 PM
pdog2000's Avatar
yes the MAPS is located right by where the windshield wiper motor is...it is also only on supercharged cars...
Old Jul 5, 2019 | 02:12 PM
StagByTriumph's Avatar
Default Manifold Absolute Pressure non-SC
I have been down this road recently and I think your photos are the Emissions Purge valve.
That Purge Valve has a vacuum line running to the Purge Solenoid that also connects to the Emissions Vapor hoses from the fuel tank cannisters and routes it to the intake.
My question is, how does a proper fuel injection system work without sensing the MAP unless it is phaked in the computer?
Old Jul 5, 2019 | 05:14 PM
pdog2000's Avatar
Is your car a non supercharged as I am not sure if the non sc have a map sensor...also in the pic where the square hole is around where the sensor mounts to
Old Jul 5, 2019 | 05:16 PM
pdog2000's Avatar
Also
see these pics ...the yellow wire is part of the connector to the map ...it is very hard to see but it’s there
Old Jan 17, 2020 | 09:33 AM
Roddyc's Avatar
Default Map sensor
I don't think anyone is hitting on my point, I'm looking for the map sensor location on a 06 Jaguar XJ8 Vanden plas. This is really frustrating, I'm getting everything except 06 Jaguar XJ8 Vanden plas
Old Jan 17, 2020 | 09:34 AM
Roddyc's Avatar
Default Map sensor
Old Jan 17, 2020 | 09:54 AM
JagV8's Avatar
If all else fails did you check the workshop manual?
Old Jan 17, 2020 | 10:50 AM
M. Stojanovic's Avatar
Took me 2 minutes to find the info (Google). https://www.jaguarforums.com/forum/x...sensor-160742/
Old Jan 17, 2020 | 11:04 AM
Roddyc's Avatar
Default Map sensor
the 06 engine is different I'm getting every engine except a 06 Jaguar XJ8. I'm finding the rest of them in 2 minutes or less also, but not so much for the 06 xj8
Old Jan 17, 2020 | 01:35 PM
JagV8's Avatar
You look to be in the wrong forum.
Old Jan 17, 2020 | 08:57 PM
The pictures you see in this forum (for X308 Jags) are not relevant to your X350 engine. On X350, the MAP sensor is bolted to the intake manifold, at the back of it.
Old Jan 17, 2020 | 09:17 PM
Roddyc's Avatar
Default 06 Jaguar XJ8 map sensor
Yes yes and yes.. thank you so much
Old Jan 18, 2020 | 01:30 AM
JagV8's Avatar
That's what has been posted in the correct forum, too.
Old Mar 28, 2020 | 10:26 AM
Vauxi's Avatar
Should my xjr AJ27sc have a map sensor ? I did have not connected vacuum hose hangin around but I dont' have sensor installed. There is only bolt holes where sensor bracket should bolt on. I do have an egr.
