Might be a starter problem '98 xj8
Old Jul 2, 2008 | 12:50 AM
GaryS's Avatar
Default Might be a starter problem '98 xj8
I turn the key andhear nothing but a very quiet click. Nothing else. All lights come on but that's it.
On a number of ocassions I have let it sit in the driveway and it will fire up just like there's nothing wrongfour or even five days later. If it does not startthefirst time the normal scenario is that it won't starteven if I tryup to six or seven times. On a couple of ocassions however it has started on the second attempt after failing the first time, but that's definately not the norm.
Luckily so far I have never been left stranded and it always happens either at home or at a friends.
Idid replace the battery, even though it didn't really appear tobe the culprit. It's been happenning for about six weeks.
Before I replaced the battery it did start up after a charger had been connected over night.........and with the charger still connected......this may have been a coincidence though.
Any ideas?
Old Jul 3, 2008 | 07:30 PM
jag_genius's Avatar
Default RE: Might be a starter problem '98 xj8
check the power studs.. to the left of the battery.. they come loose.. and melt and give the same problems as you speak of.. also there is one under the hood.. right side under the cover.. they melt as well. they give intermittent no starts..
Old Jul 4, 2008 | 12:41 PM
GaryS's Avatar
I have heard of the one up front and checked that already and it looks good. I will check by the battery later today.................Thanks for the suggestion.
Old Jul 6, 2008 | 12:57 AM
GaryS's Avatar
Everything looked in good shape. Any other ideas?
Old Jul 6, 2008 | 01:12 AM
GaryS's Avatar
Totally appreciate your suggestions.........on a side note I bought the car in San Diego and droveit to Seattle and before leaving SD I found a great mechanic (English with decades of Jag experience) who did the Timing Chain Tensionersand a bunch of other stuff.
Anyway he has basically been giving me same advise as you................it just seems a little tough to diagnose.
Old Jul 26, 2008 | 02:27 AM
alckc's Avatar
can i get the name and telephone number of the jag mechanic. i live in los angeles, but willing to go to sd unless anyone else knows of a good jag mechanic in los angeles. thanks
Old Jul 27, 2008 | 10:02 AM
Brake buster's Avatar
its the transponder/immobilizer thats at fault
the aerial in the steering column cowl gets damaged, this restricts the strength and range of the signal to pick up the chip in your key
your symptoms are typical of this problem
new imobilizer antenna required
BB
Old Jul 28, 2008 | 11:14 PM
GaryS's Avatar
Thanks BB.alckc, I sentmy San Diegomechanic's name andnumberto your email.He is a great guy. If you don't get it,post again. Too bad I am in Seattle.
And BB,Iowe you an apology of sorts.Isaw a post you placed to a simillar sounding problem to mine and I am embarassed to say that I totally discounted your advise in that previous postas it sounded so crazy..................this time I will follow up on it. (Little did I know)Thanks again.....Gary
Old Oct 15, 2008 | 03:23 PM
GaryS's Avatar
Just wanted to post an update:
I finally took my car into a jag machanic I haveused in the pastandit wouldn't start the morning they were going to work on it.
They replaced the starter motor and it's been fine ever since.
Thanks to everyone who responded to my post.
Gary
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
jdzubas
Oct 4, 2015 09:14 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
TC Johnson
Sep 2, 2015 09:30 AM
