Mina Gallery intake kinda lacking?!?
Old May 21, 2024 | 08:06 PM
24ounce's Avatar
Default Mina Gallery intake kinda lacking?!?
Installed the direct intake today and to be honest felt more like the 49 dollar honda civic special. The main issues besides the heat shield being floppy doppy (I'm assuming not so much with the hood or bonnet closed) is it really feels as though it's missing a piece. The filter (which is different than what's pictured in their ad) they want direct clamped to the MAF. Not the biggest issue minus the fact it don't fit through the cutout in the heat shield also leaving the sensitive MAF not hard mounted and also just kinda there.
It's nice that there is an option for this vehicle (kinda) but it really needs a coupler or extension pipe from the MAF to the filter. The filter also doesn't sit ideal. Instructions were also fairly lacking but living my past life as a FoMoCo tech poor or lacking instructions doesn't fase me much.
All in all it's installed and seems to function and I'll probably be leaving it. Just an honest review for anyone who may find it helpful.
(I bent the filter slightly man handling the thing to try and get it mounted)
Old May 22, 2024 | 11:15 AM
Mvirgil's Avatar
The air filter is not really a restriction, the intake tube is. Going to a larger 3.5'' pipe livens up the motor nicely; stock the intake tube has fairly high restriction. Lots of posts and pictures on the forum's
few different set ups pictured here with and without the filter box
https://www.jaguarforums.com/forum/x...-112356/page2/
Old May 22, 2024 | 11:28 AM
03_jaaag's Avatar
ive heard it makes the s/c louder. is that true?
Old May 22, 2024 | 12:40 PM
Mvirgil's Avatar
Makes it so you can hear it, nothing obnoxious. Much better higher rpm pulling, felt like I had added a pully. Pretty sure people have some before and after numbers form long ago.
Old May 22, 2024 | 02:43 PM
24ounce's Avatar
Agree with the slightly better intake/ charger sound
Old May 22, 2024 | 02:54 PM
24ounce's Avatar
Thank you for the link as full tube fab is on the list and this takes a good bit of the mock up out of it.
Thanks guys
Old May 25, 2024 | 07:39 AM
Z07Brandon's Avatar
The intake tube is the restriction. The filter, not really.
Old May 25, 2024 | 07:09 PM
Addicted2boost's Avatar
https://www.siliconeintakes.com/alum...se-p-9675.html
This 3.5” carbon fiber tube is what I have on my car. It doesn’t look quite like waterdragons but close. I also used T bolt clamps instead of regular hose clamps.
Old May 25, 2024 | 07:30 PM
24ounce's Avatar
Thank you 👍🏼👍🏾👍🏿👍🏻
Old May 26, 2024 | 07:12 AM
Quadcammer's Avatar
Another option. It was cheap and easy
Old May 26, 2024 | 08:03 AM
Mvirgil's Avatar
is that a 3.5'' tube with a 90 degree 2'' mandrel bend + 30 degree coupler? Was not the biggest fan of the air box+cone filter I made on my 98; yours looks very good.
Old May 26, 2024 | 08:33 AM
Quadcammer's Avatar
Let me go back and look at the order but that sounds right. I ordered the 30 and tube from silicone intakes. The 90 is a reducing 90 which is a bit hard to find and I had to cut it down to get hood to close, but overall pretty easy to do
Old May 26, 2024 | 11:47 AM
24ounce's Avatar
Reaxions
Apr 23, 2024 10:10 AM
Ashton Dimovski
Mar 14, 2022 12:53 PM
BlownBrit
Nov 29, 2016 02:50 PM
exexpat
Nov 5, 2013 03:29 AM
BigTexx
Jan 30, 2013 12:46 PM
