Need T17 Torx for Throttle Position sensor
Old Aug 16, 2021 | 03:57 PM
David N. Warner's Avatar
Default Need T17 Torx for Throttle Position sensor
Hello,
I have been getting the code for a throttle position sensor on my 2000 VDP so I purchased one. When I went to change it seems I need a T17 Torx bit. You cannot imagine how hard it is to find. Any ideas where one could find one of these bits?
Thanks, Dave Warner
Old Aug 16, 2021 | 04:41 PM
Carnival Kid's Avatar
While the T17 Torx does exist it does seem to be almost as rare as rocking horse manure.
Are you sure a T20 doesn't fit?
As a last resort, apparently the T17 Torx exists in the UK bicycle world.......
https://www.ebay.com/itm/28418166499...UAAOSwJcJhEldq
Old Aug 17, 2021 | 05:47 AM
jrb53's Avatar
Default Torch set
Originally Posted by David N. Warner
Hello,
Thanks, Dave Warner
you can but a set on Amazon get the set that fits onto a ratchet
Old Aug 17, 2021 | 08:22 AM
M. Stojanovic's Avatar
Even Walmart have it: https://www.walmart.com/ip/K-Tool-In...t-ea/586996810
Old Aug 17, 2021 | 09:12 AM
Originally Posted by M. Stojanovic
Well, sorta, it says out of stock, so doesn't count.
Old Aug 18, 2021 | 12:25 PM
60Gunner's Avatar
Ive got at least a half dozen of them I've aquired over the years. Maybe they were more available years ago?
Or I bought 'em all.
Old Aug 19, 2021 | 07:35 AM
I managed to get the screws out with vice grips so I'm OK at the moment. Thanks for checking guys! If Walmart gets some available I'll buy one....
Old Aug 22, 2021 | 03:01 PM
Addicted2boost's Avatar
I know I’m very (fashionably??) late to the party but, the size you needed is a TS20.
Protool 5-Point Star Tamper-Proof Bit Set-Fits Many German Cars-T10 to T50-Taiwan, Metal
Amazon Amazon
This is what fit in my throttle bodies TPS. Better late than never right?
Old Aug 23, 2021 | 09:03 AM
Protool 5-Point Star Tamper-Proof Bit Set-Fits Many German Cars-T10 to T50-Taiwan, Metal https://www.amazon.com/dp/B007SOODHC...ing=UTF8&psc=1
Hello,
The TS 20 takes off the side of the throttle body where the TPS sensor is screwed onto and those are TS20 Torx. The actual TPS screws are smaller and not security type...I suspect they felt that using a T17 would be harder than finding a TS bit! Attached pix shows beat up screws after trying a number of bits and screw drivers
Old Aug 23, 2021 | 10:07 AM
The black screw away from the TPS (as shown on the above picture) is a standard 6-point Torx, just Temper-Proof, The screw holding the TPS should be the 5-point "TS" bit so it cannot be the T17 which has 6 points. Perhaps T17 is the popular Torx bit used to mangle the 5-point socket in the screw?
Old Aug 31, 2021 | 08:43 PM
Well that is just swell! Thanks much for the advice and the link! Much appreciated!
Old Dec 20, 2022 | 08:38 PM
Julia700's Avatar
Hi , does anyone know the part number for the TPS to throttle body TS20 mounting screws?
failing that, any TS20 alternative?
I suspect mine have the heads ruined.
cheers
Old Dec 20, 2022 | 09:17 PM
The only way Jaguar would have that fastener is with the rest of the TB. In the past I have used a needle nose vise grip on the screw head itself. It would be ideal to remove the TB from the engine to get the bottom one out. Over here in the states I would go to an ACE Hardware to quite possibly find at least a suitable replacement bolt in place of the TS20 5 star as they have a wonderful selection of fasteners. I’m not sure where to go in the UK as I’ve not been there.
Old Dec 21, 2022 | 06:01 AM
RandyS's Avatar
Yes, and I can't quite figure out what Jaguar was thinking with these fasteners. Was it just to keep
the shade=tree mechanics off-balance? Some more compelling reason?
Old Dec 21, 2022 | 09:53 AM
Sean B's Avatar
I'd bet a much more 'common sense' reasoning behind the awkward bolt heads - Engine protection and safety. The throttle body is not a serviceable part, service technicians replaced the complete unit, not the TPS.
It's also the main component in engine management, and this is something not even Jaguar can alter drastically - only updated throttle calibration and ECU maps. Software, not hardware.
With Denso copies readily available these non service items get the torx treatment when they're slightly different star/penta, enough to screw them up and do their security job.
Old Dec 21, 2022 | 11:30 AM
Julia700's Avatar
So all we need then is the length and determine what thread it is. I don’t care what head it has, the easier the better! Can’t believe no one has done this swap out before… these screws are worth peanuts!
prodigy215
Dec 28, 2022 11:23 AM
thom4782
Aug 2, 2021 05:46 PM
fredd60
Oct 21, 2019 07:46 PM
Vandyone
Jul 26, 2018 01:19 PM
baycliffpwds
Sep 26, 2010 11:57 PM
