Need x308 xj8 steering rack transducer
Old Feb 20, 2023 | 06:45 PM
VDP P's Avatar
Default Need x308 xj8 steering rack transducer
Hi, my 2002 x308 is in need of a “steering rack transducer” also known as variable assist power steering solenoid. Can anyone help me to find one? Only one I see is in the UK and they will not ship to the USA. Thank you in advance.
Old Feb 20, 2023 | 07:56 PM
David N. Warner's Avatar
How about this one from Ebay? ( I made the link tiny)
tinyurl.com/msmw3bxx
Old Feb 20, 2023 | 08:35 PM
VDP P's Avatar
This is the part I need- thank you! Sorry trying to upload a picture of the solenoid
Old Feb 20, 2023 | 09:01 PM
VDP P's Avatar
I believe it’s part number ZF 7039-442-214 it is variable assist power steering solenoid.-also known the steering rack transducer. According to the dealer this part does not have a Jaguar part number. Thanks again!
Old Feb 21, 2023 | 03:50 AM
M. Stojanovic's Avatar
You should go by the Jaguar part number. LNE2100AA (the one shown on the provided Ebay link) is correct for your 2002 car because it is for use on VIN 853936 (~1999) and higher.
Old Feb 21, 2023 | 07:20 AM
xalty's Avatar
he needs the rack solenoid not the VAPS controller
Old Feb 21, 2023 | 08:35 AM
VDP P's Avatar
Thank is correct
Old Feb 21, 2023 | 08:36 AM
But when given the link "tinyurl.com/msmw3bxx" (which shows the part on the pic below), VDP P said "This is the part I need- thank you!". Perhaps this needs to be clarified.
Old Feb 21, 2023 | 05:16 PM
What is the problem with your car? Does it behave like there is no power steering? It was the control module in my case.
I seem to recall you can measure between the pins on the part on the steering rack though I don't recall what it should read on the meter.
Old Feb 21, 2023 | 05:32 PM
VDP P's Avatar
Yes the solenoid was tested with an ohms meter and was out of spec, thus sending incorrect pressure to the pump/rack
Old Feb 24, 2023 | 10:12 AM
Did you find that part you need? I have a wrecked 1999 XJ8 that may have one that is OK. I'll send it to you if you want it.
Old Feb 24, 2023 | 10:21 AM
VDP P's Avatar
Thank you I did find the part
Old Feb 25, 2023 | 09:11 AM
Great! Another VDP will be back on the road again!
Old Mar 3, 2023 | 10:40 PM
VDP P's Avatar
Thank you - actually a 2002 super v8, new solenoid solved the problem!
VDP P
Feb 15, 2023 08:46 AM
cds
Jun 1, 2016 11:21 AM
Daim
Feb 21, 2016 06:55 AM
DJ-Roy
Jul 19, 2014 10:32 PM
Rique
Oct 2, 2009 03:19 PM
