No starter turnover, Battery good.
Old May 6, 2014 | 06:31 PM
ocphippsjr's Avatar
Default No starter turnover, Battery good.
My 2000 VDP gets nothing when I turn the key to start. Did load test on Battey, it is strong. Any suggestions?
Old May 6, 2014 | 07:35 PM
BigTexx's Avatar
I'm not sure how much work it is to drop a starter on the XJ's since I haven't dealt with the problem yet but I usually start with the easiest thing first. Drop the starter and take it to your local auto parts store and have it tested and go from there. Testing is free usually.
Old May 6, 2014 | 07:36 PM
sparkenzap's Avatar
Have a look at the "false bulkhead" power connectors on the outside of the boxes at each side of the firewall. Then check the power connections on the fuse panels. Check the inertia shutoff switch. With some more info concerning the condition of lights and dash indicators someone can help you narrow the search for the cause.
FWIW, "dropping the starter" is a royal PITA on these cars, so a lot of diagnostics should happen before embarking on that adventure!
Old May 6, 2014 | 10:09 PM
avt007's Avatar
Please don't buy anything until you've gone through the Electrical troubleshooting link that is in my signature.
I'd suspect a bad engine strap.
Run through the steps and let us know what you find. Good luck!
Roger Geirnaert
Oct 12, 2015 01:01 PM
Jahnese Alston
US Northeast
Sep 20, 2015 02:22 PM
GGabriel
Sep 18, 2015 08:44 PM
Charlene n John
Sep 14, 2015 10:08 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
