No traction control and no automatic stability control
Old Apr 10, 2025 | 05:35 PM
Eric2000jag1's Avatar
Default No traction control and no automatic stability control
My 2000 xj8 vdp is showing “traction control unavailable” and “asc unavailable” on the instrument cluster. What can be causing this? I already cleaned the wheel speed sensors and it didn’t help. Any suggestions would be greatly appreciated. Thanks in advance!
Old Apr 10, 2025 | 06:10 PM
Peter_of_Australia's Avatar
The 2 most likely culprits for this kind of failure are:
1. Check all inline connectors to all 4 speed sensors for contact and corrosion. Clean them and apply CRC 2.26.
2. But sadly the most likely fault are cold welds (=cracked solder points) inside of the ABS module. The complete ABS-PCB was in a solder-bath during production for a fixed duration, and this time was long enough for all the smaller solder points, but not for the 2 big ones, where the power comes in - and this shows now - years later, There 2 big solder points need to be re-soldered. It's a bit of the struggle to get the ABS module off and on again, but I did that on my X308.
Here is a video about it - I have not seen the video in its entirety, but the important part starts at time 3:45:
I can't remember if I drilled a hole into the cover like shown in the video, or of I managed to pry the lid open...
Old Apr 10, 2025 | 06:28 PM
motorcarman's Avatar
pcolapacker sent me this pic of one of his ABS modules
Old Apr 11, 2025 | 04:38 AM
Alex_O's Avatar
Changing the battery for a 100amp fixed it for me
Old Apr 11, 2025 | 09:45 AM
RandyS's Avatar
Low voltage across the connection joint can cause the issue which is most
likely caused by the solder point weakness. Isolating the problem and completing
a refresh of the weld is the most effective manner of eliminating the warnings. There
is a lot of vibration at this connection which exacerbates the issue.
dibbyandco
Oct 15, 2025 04:53 PM
BigTurk
Jan 25, 2022 01:45 PM
FullChat
Feb 26, 2018 11:20 AM
WallaWalla
17
Feb 27, 2012 11:45 AM
deerebill
Jun 1, 2010 09:45 PM
