P1316 & misfire on all cylinders
Old Mar 22, 2025 | 03:49 PM
Nick M's Avatar
Default P1316 & misfire on all cylinders
Hey all! Like the title states. Car is not running at all. Will crank over just fine & will run on starting fluid. It's not getting fuel for one reason or another. In my mind it's the fuel pump, or the injectors are not being ordered to deliver fuel. What do you all think?
2001 xj8 4.0
Old Mar 22, 2025 | 04:00 PM
Hooli's Avatar
It's normally the fuel pump.
I'd start by bridging the relay contacts in the fusebox by the battery, you should hear the pump running in the tank if it's working. Then work from there.
Old Mar 22, 2025 | 04:05 PM
Parker 7's Avatar
There is a specific fuel injector relay
You can jumper the # 1 fuel pump relay between socket 3 and 5 with a medium gauge wire with blade type wire ends
The common auto parts store can make one from a kit under the cash register , maybe for free
This will have the pump run at all times so will drain the battery with keys in pocket
Nick M's Avatar
Would turning the key give me the same effect?
Old Mar 22, 2025 | 04:37 PM
Nick M's Avatar
In the manual, they're all labeled R1, except accessory which is R7.
Old Mar 22, 2025 | 05:17 PM
Parker 7's Avatar
With the turning of the key the fuel pump will run for 3 seconds only then off
once the CKPS sees engine rotation the pump will come back on for the duration of your drive , safety design
So you will have 3 clicks of the # 1 fuel pump relay , on - off - on , there is a backdrop relay and secret fuse involve to get the fuel pump relay to click
Old Mar 22, 2025 | 05:22 PM
Parker 7's Avatar
Old Mar 22, 2025 | 07:57 PM
Nick M's Avatar
@Parker 7 Thank you for the diagram. I jumped the relay with no response. I'll put a pressure gauge on it just to confirm.
Old Mar 23, 2025 | 11:44 AM
Parker 7's Avatar
With a good ear you can hear the pump first 3 seconds from the cabin , better with the trunk fwd liner removed and listen in trunk
There is a fuel pump ground wire post for the pump alongside the battery area
So large 2 sockets 3 and 5 on the relay holder ? socket 3 should be hot at all times from battery and the big power fuse ( # 15 / 20 amp ) is after the relay
pic coming
Old Mar 23, 2025 | 03:01 PM
Jhartz's Avatar
Might first try resetting the fuel cut off switch: inside the footwell on the right side under the carpet.
Old Mar 23, 2025 | 09:23 PM
Nick M's Avatar
@Jhartz I tried it. No luck. Thanks for the heads up, though.
Old Mar 23, 2025 | 09:27 PM
Nick M's Avatar
@Parker 7 Thanks for all the diagrams. They were a big help. I searched the site, but didn't see a writeup for a fuel pump swap. Do you know if there's one on record here?
Old Mar 24, 2025 | 02:18 AM
Parker 7's Avatar
With the normally aspirated you will only have the # 1 pump , Supercharged 2 pumps
With the crash / inertia switch it is fickle and does not always reset from reading others , this crash switch only effects the control of the fuel pump relay and not a direct powering by jumpering socket 3 to 5
You can use a paper clip between wire X and wire Y of the connector , paper clip works fine for my inline 6 X300 with different wire colors
tanios
Jun 20, 2024 07:32 AM
98Jagxjr
Dec 27, 2022 06:59 AM
Adammarqq
Dec 18, 2022 07:32 AM
Rnanc44
Jan 15, 2020 10:37 PM
jagboy96
29
Jun 11, 2013 04:46 PM
