Power steering pump on a 2002 XJR
Old Oct 5, 2015 | 01:19 PM
Terry007's Avatar
Default Power steering pump on a 2002 XJR
Hello
I have been told that the Lincoln LS and the 2002 XJR have similar engineparts .
A -Am I correct?
B-Do you know if this apply to the water pump and pressure hoses ?
C -Do you know the parts number ?
Thank you
so much''
Terry
Old Oct 5, 2015 | 02:14 PM
Jhartz's Avatar
Why not try Amazon and compare?
Gaudin Jaguar parts in Las Vegas has a complete on-line parts catalog for searching numbers: then try Amazon, Parts Geek, oe eBay for best price.
Some Ford sourced parts are common across Lincoln, T-Birds, and Jags (mostly S-types).
On the Land Rover forum, they used show common parts: the price differences were surprising (one plastic engine fitting was 18c for Explorer; $2.80 for LR3). Timing gear for Lincoln LS are essentially the same as early AJs. One local guy saved $15 and three days buying from our Lincoln dealer instead of from Christopher.
Old Oct 5, 2015 | 03:15 PM
Terry007's Avatar
Thank you Jim,
You are correct
The Jag dealer wants 875 dollars here in Los Angeles for a 2002 XJR power steering pump .i found one on geeks parts for 187 dollars .
Old Oct 5, 2015 | 08:53 PM
yeldogt's Avatar
The Jaguar V8 motor was used by Land Rover when they were common ownership -- and Ford swiped the V8 for the LS and the thunderbird -- different heads. The X308 also has small bit throughout that came from other cars .. but not much.
Old Oct 5, 2015 | 11:12 PM
Terry007's Avatar
So would you say that the Power Steering pump and assembly on Jaguar 2002 XJR is similar the one on the Lincoln LS ?
JAG dealer wants over 875 for the PS alone !
Old Oct 6, 2015 | 07:52 AM
yeldogt's Avatar
My guess would be ... No.
I believe they are offered as rebuilt in the aftermarket. This would also be something that I would possibly get used if from a reliable source and cheap enough -- they have a low failure rate.
Old Oct 6, 2015 | 11:55 AM
Jhartz's Avatar
There are a couple of junk yards specializing in Jags and Land Rovers in the LA area. You should be able to get a good used one. Also in Stockton there is a breaker that specializes in Jags. Back here, nothing close.
Old Oct 6, 2015 | 12:32 PM
Terry007's Avatar
thank you Jim
I m going to see if i can find those junkyards
Terry
Old Oct 6, 2015 | 01:05 PM
avern1's Avatar
The one in Stockton is called Jaguar Heaven. You might also try everdayXJ. He parts out XJ's
ksjaguar
Nov 3, 2015 10:14 AM
vwbusbits
Oct 13, 2015 03:43 AM
speeeeedfreeeeek
Oct 6, 2015 04:38 PM
Col. Sandurz
Sep 28, 2015 12:49 PM
Saturbo
Sep 8, 2015 07:35 PM
