Purchasing Throttle Position Sensor
Old Feb 6, 2019 | 08:35 AM
prodigy215's Avatar
Default Purchasing Throttle Position Sensor
Does anyone know where to purchase Throttle Position sensor from? The dealerships said it's not sold separately. The only place I see it sold on is Amazon and it's not OEM. How did you guys go about purchasing a new TPS? Help. Thanks!
-2003 VDP
Old Feb 6, 2019 | 10:16 AM
King Charles's Avatar
Old Feb 7, 2019 | 05:00 AM
prodigy215's Avatar
Old Feb 9, 2019 | 05:51 AM
staffsbull's Avatar
I saw this too, its from a place in Scotland. DCR Autoparts on 01456 450756....not sure about prices though
Old Feb 10, 2019 | 09:25 PM
prodigy215's Avatar
I replaced sensor with one I purchased from Amazon. So far so good!
Old Jun 8, 2022 | 02:00 AM
Bmansfb's Avatar
Default Ebay
-2003 VDP
Ebay
Old Jun 8, 2022 | 03:33 AM
Bmansfb's Avatar
-2003 VDP
Stay away from the unbranded ones as they tend to only have a single potentiometer. And right now there seems to be an abundance of entire replacement throttle bodies with the sensor for cheaper than I can find a solo Denso sensor .
Old Dec 22, 2022 | 06:08 AM
Julia700's Avatar
I had to send the one from Scotland back, as it threw up loads of other codes when my mechanic fitted it.
the best one I used is from Berkshire Jaguar
Old Dec 23, 2022 | 09:38 AM
RandyS's Avatar
Denso usually works out for me.
Old Dec 23, 2022 | 01:11 PM
Addicted2boost's Avatar
Randy, I’m fairly sure Denso doesn’t make one for our cars as a replacement. Yes, I know they were the original makers of our TPS’s but, I guess they weren’t allowed (?) to make them for individual parts sale. Up until about 4-5 years ago, we couldn’t even get an aftermarket one. We were relegated to either buying a used TB or buying an entire new ($$$$$$$) TB from Jaguar. I bought an aftermarket TPS from eBay about 4-5 years ago for my own car as a spare (about $25) and I’ve installed it on a few customers cars to diagnose their original failing tps and the AM one performed great. I wish Denso made a direct replacement tps for our cars.
Old Dec 23, 2022 | 02:00 PM
RandyS's Avatar
Yes, it is true….however, what I was trying to say was
that…given a choice, I would seek the Denso name even
if it was a used OEM part. The AM one probably works
fine, and it could be all that was available and a logical
choice when push comes to shove.
Old Dec 28, 2022 | 10:56 AM
Hooli's Avatar
Just to add to this, there are two TPS & we can still only get one.
I was getting TPS error codes on mine & initially the sensor as pictured in this thread fixed it. But then it came back, but only when the cruise control was 'armed'. There's a second TPS at the throttle cable end of the throttle body so it seems, I had to get a second hand TB and fit that to fix my cars issues. Helpfully by changing a couple of external parts (inc a water feed on the back of the TB) you can fit a supercharged car with the TB off an NA one as the actual TB is the same size.
Old Dec 28, 2022 | 11:02 AM
vincent661983's Avatar
why don't just send the TB for rebuild ? I did it with 2 TBs
( I also went extra steps...will be another story telling)
Old Dec 28, 2022 | 11:06 AM
Hooli's Avatar
In my case I couldn't find anywhere to rebuild them & the second hand TB was about £60-70 so cheap enough to try.
I've still got the faulty one though, so I could get that rebuilt as a spare one day, anywhere you suggest for it?
Old Dec 28, 2022 | 11:23 AM
I used this company. I purchased the rebuild service through eBay thou.
https://www.autoecu.com/
In addition, I used another company to bore/port ( don't quote me which team, the center diameter is unchanged) after the rebuilt.
I needed to do that because it is a part of a even bigger project and story- full Supercharger rebuild ,porting and powder coating.
on and on
Apr 17, 2019 04:33 PM
Stounedi
21
Dec 23, 2017 06:33 AM
'05 STR
Feb 14, 2016 08:33 AM
juha_teuvonnen
Dec 17, 2014 09:35 PM
sws805
Jan 24, 2013 10:58 AM
