Radio Cutting Out..,?
Old May 31, 2016 | 02:25 AM
xjrjag's Avatar
Default Radio Cutting Out..,?
My radio likes to cut out every so often. Doesn't matter what station it is on. It has done this ever since I got the car. It also happened in my X-Type when I had it, so I'm just starting to think it's a Jag thing. Has anyone else experienced this? If so, what would be the cause?
Old May 31, 2016 | 09:09 AM
Samilcar's Avatar
What does the display say when it cuts out? I had an issue with the radio cutting out and displaying "Phone" on the display. This kept getting worse over six months and was solved by replacing the head unit with a used one.
Old May 31, 2016 | 10:38 AM
Highhorse's Avatar
Sounds like a bad cold solder joint.
Old May 31, 2016 | 03:31 PM
xjrjag's Avatar
No, there is no message that displays. It plays just fine and then randomly will be a blip of silence and then right back to playing. Happens pretty frequently. But like I said, my X-Type did the same exact thing and that had a different type of head unit altogether.
Old May 31, 2016 | 03:33 PM
Mark SF's Avatar
My Land Rover Discovery had a similar problem, and the mute button on the steering wheel was faulty. It was putting the radio into mute mode. I figured this out after fitting a new radio, and having the same problem.
Old May 31, 2016 | 03:44 PM
motorcarman's Avatar
Does ANYONE ever read the TSBs I (and others) uploaded to the large file area?????????????
Look at 415-07 Amended.
I seem to post this and other Radio issues several times a year.
Here they all are AGAIN.
bob
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old May 31, 2016 | 08:41 PM
ericjansen's Avatar
Keep them on stand-by Bob, this will not be the last time .
Old Jun 3, 2016 | 10:46 AM
vdpnyc's Avatar
Mine cuts out too, got progressively worse and now almost never works.
It ONLY happens on FM, not on AM or using another music source. I've checked the antenna connectors in the trunk, by the amp and behind the radio head in the dash, and have ran out of ideas how to fix...
Old Jun 3, 2016 | 11:21 AM
Highhorse's Avatar
I'm pretty sure I still have my old head unit, cd and amp if your interested? PM me and make me an offer if you'd like any of it.
Old Jun 3, 2016 | 12:07 PM
vdpnyc's Avatar
Thanks, but I gave up on this and earlier this week i wired the car with an aux-in and Bluetooth over the CD input, so no need for fm
Old Oct 5, 2019 | 09:41 PM
Jayblair's Avatar
Default Communication Fault
Hello, I have a 2008 xj 8 and my stereo goes mute and display says communication fault. Any answers will be helpful.
Old Oct 6, 2019 | 06:05 AM
Vauxi's Avatar
I looked in to my radio which had totally broken FM and AM input. Fm didn't find any stations and therefore nothing but static out from speakers. Navigation and deck and cd input worked ok. Turns out that blue jelly on top of the pcb caused one pin of the cpu to rust broke. Bought used one from Ebay and after quick test on the bench opened it up and same corrosion happening there but I was able to remove jelly and seal up the pcb.
For me it look's like these radios has nasty issue coming up in few years..
coldpad1
May 6, 2021 03:40 PM
avern1
May 5, 2016 01:49 PM
StuG
Australia - Queensland
Apr 26, 2016 08:49 PM
agd
Apr 22, 2016 09:57 AM
NW1996
Apr 3, 2016 06:56 AM
